ASE Master Tech - 35 yrs
larrym's Avatar
Question why stagger frt/r wheel & tire sizes?
this old thread made me wonder what the benefit is of staggered sizes front/rear,
What size tires for 16 x 8 Fuchs on a SC?
i.e. why 7&8 vs all 7s or all 8's? or 6&7 vs all 7s?, etc
- is it mostly a factor of 40/60 rear engine 911s, (or the SWBs 35/65 where tail-happy was a serious concern)
- is it even relevant to more balanced cars
like 914's (46/54) (or 914-6 at 49/51 according to Hemmings ???) ?
- or maybe 50/50 Miatas?
this for grist: - Stop and weight! A 50/50 weight distribution is not optimal | Automotive Thinker - Discussing the finer points of automobiles
If it works, take it apart and find out Why.
Old 12-02-2017, 10:07 PM
Undocumented User
McLaren-TAG's Avatar
To maximize the transfer of power to the road, you want bigger tires over the drive axle. You want bigger tires still over the drive axle that the engine sits on.
Honda civic drag cars have the big tires up front.
Old 12-03-2017, 04:21 AM
billybek's Avatar
Perhaps more traction when "lifting" off throttle in corners?
Bill K.
Old 12-03-2017, 04:44 AM
Vintage Owner
Jack Stands's Avatar
To help control off throttle oversteer. If you drive an early 911 and lift off the throttle in the middle of a corner, you’ll understand the meaning of ‘loose’ that NASCAR drivers use. A quick way to back into the guardrail! The wider rear tires tame this behavior significantly.
84 Targa
70 914-6
73 914-6 2.7 conversion (sold)
75 GMC Motorhome
Old 12-03-2017, 05:25 AM
larrym's Avatar
Question
yes - i owned a swb 911 - know all about that and had the experience
but i constantly read about people staggering wheels on cars that are a good bit more balanced (see above) - why?
? maybe it's just for the cafe racer "look"?
as for honda dragsters - that's a quite different straight-line objective
Old 12-03-2017, 10:05 AM
Toyota MR2 came stock with staggered tires.
I replaced with same size tires all around
and it handled much better (more neutral vs. understeer)
I wouldn't try that on a 911.
Big ass rear tires keep the pointy end in the right direction.
Manufacturers build in too much understeer.
'87 911 G50 Coupe Granite Green / '90 VW Westfallia Camper
Priors: '83 911SC Cab, '67 Lotus Elan, '65 Porsche 356, '74 Porsche 911, '70 914 Porsche, '00 BMW M Coupe, '96 M Miata, '01 MR2 Spyder, LandCruiser FJ60.
Old 12-03-2017, 10:33 AM
larrym's Avatar
so i asked google "do wider rear wheels cause understeer"
this pelican thread from 2006 is on top
What is effect of difference in wheel track width on handling?
and that gets to the universal question - "What are you going to use the (fill in the blank) for?"
- same thing the BestBuy salesperson asks about every tech gadget we look at
I should have asked: "on a street car? - what's the benefit"
Old 12-03-2017, 10:53 AM
Bill Verburg's Avatar
track width is not the same thing as wheel width
the answer to you original ? is that a tire has a friction circle
the more work it does in acceleration the less it can do in cornering, the more in braking the less in cornering and vice versa
Typical friction circle diagram
when the rear wheels are also drive wheels to get more total grip you use wider wheels/tires in back. Even front engine cars like Camaro and Mustang do that. As do more balanced cars like mid engine Cayman and Ferrari.
The 911 and all it's derivatives have an additional impetus in itheir weight distribution.
Bill Verburg
Old 12-03-2017, 11:07 AM
Hey, nice marmot.
tirwin's Avatar
My MB E350 has staggered wheels too.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 12-03-2017, 11:40 AM
