how to take out the pedal assembly please?
hello anyone can chime in on how to dis-assemble the pedal assembly from the car? i have a 81 sc targa So I can clean it up. thanks
06 E55 600HP 08 Clk63 black series 590HP 81 SC targa 3.0 91 E34 M5 |
I sent about 10 minutes writing a "How to" for you, then on checking a small fact I remembered Wayne had posted a how to on Pelican, so here it is....
Porsche 911/914 Pedal Cluster Rebuild | 1965-1989 | Pelican Parts DIY Maitenance Article
Anouska's Daddy 1995-2005 and Forevermore |
A tip for making the job easier is disconnect both the flat bar and the long round rod at the top and remove the cluster with both pieces attached. Mark the angle of the flat bar and reassemble the same. Reinstall the assembly same as removed.
thank you guys! I really appreciate it.
one question i do have is how to take it out from the floor pan? is it just two screws in front of the pedals or is it also the two screws on the fire-wall? thanks
Two more bolts from UNDER the car.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Try here for most all repair answers:
Porsche Workshop Manuals |
thanks
