question about rolling car w/o trans
I'm without an engine and trans at the moment.
Figured this would be a good time to get some rust repaired on the car.
I need to tow my car to a body shop to get some rust repaired..
What's the best/safest way to roll the car without a trans?
1987 Porsche 911 Carrera Coupe
Old 12-19-2017, 07:12 AM
gearhead
Wat? Push it...
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 12-19-2017, 07:19 AM
I would rather be driving
jpnovak's Avatar
Pull the CV shafts, secure the heater hoses and clutch cable, seal off the oil system and take it wherever you want.
Old 12-19-2017, 07:20 AM
disband
juanbenae's Avatar
flatbed it. tie the axels up so they can spin freely, or better yet remove them from the hubs and proceed.
Old 12-19-2017, 07:21 AM
great.... thank you.
Wasn't sure if I should pull the axles or if I could just let them hang with some wire support to allow them to spin....
Is it difficult to pull them off the wheel hubs???
Old 12-19-2017, 07:37 AM
disband
juanbenae's Avatar
not much different that the inboard side, just a little tighter quarters. use a screw driver in the vented portion of the rotor up against the caliper to hold it from spinning when loosening. careful though, while you are hold the screw driver to cleat it against the caliper you can pinch the shat out of your hand has it spins to "lock in". as me how I know....
Old 12-19-2017, 07:41 AM
Half shafts........
You can not remove the Carrera 3.2 half shafts (‘87) if you need the rear wheels installed for moving the car. Use some strong wires to hang the half shafts (axles) to allow them to rotate freely.
Tony
Old 12-19-2017, 08:05 AM
jpnovak's Avatar
Didn't look it was an 87 G50 car. Yes, correct. Tie up the axles with wire. You can loop over the shock towers. They are almost directly above the axles. Get them to hang level and you will be fine.
Old 12-19-2017, 10:20 AM
Tony
Ok... thanks for this info. that's what I'll do then...
Old 12-19-2017, 01:43 PM
If you pull the halfshafts be sure to leave the splined axle stub in the hub. Rolling it or stepping it down on a flatbed can cause the hub to pull away from its inner bearing half. I was skeptical about this but actually saw it happening when I had the rolling chassis I bought shipped to me. Short term solution was to use long heavy bolts through the hubs with some big washers on either side. Tightened it up and it was good to roll.
Old 12-19-2017, 04:24 PM
3rd_gear_Ted's Avatar
Put a nut & bolt through the inner CV joint pieces to hold them together.
Bag the CV joints.
Suspend the half shafts with motorcycle tie down straps horizontally.
Use the winch you bought at Harbor Freight
1980 911 - Metzger 3.6L
2016 Cayman S
Old 12-19-2017, 04:52 PM
Location: behind the redwood curtain, (humboldt county) california
Keep speed down!!
Keep the speed down to a crawl, or it is possible that the axles will whip around like a mad thing, ripping out the wiring harness, clutch cable or anything else it can get a hold of.
Bagging the inner cvs will keep everything from sharing the grease and conversely, it will keep trash/dirt out of the cv grease.
Chris
Old 12-20-2017, 02:37 PM
