Relay or Control location
I am desperately tring to locate the power window relay or control unit on a 86/87 Carrera RHD Euro build.
I have power at number 1 fuse but nothing at the door switches
Any help would be appreciated
Thanks in anticipation
Clive
Clive Turnbull
Cheshire
UK
Old 02-12-2003, 03:12 PM
GFCC
Jeff's Avatar
Clive, on the U.S. version... 86 relay is located in the luggage compartment. Second relay (counting from the back of the car to the front). For 87 it is located behind the Oil level/ Gas gauge. First one from the driver's door.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 02-12-2003, 03:26 PM
Jeff
Many thanks. I am told by my friend(owner) this is an 87 model and it definitely isn't in with the fuses in the luggage area. Problem is now that we are right hand drive. I did find 2 relays behind the instruments on the far right of the vehicle but when we asked the spares man he said these are washer relays and he couldn't pinpoint the location of the window relay. I will have a scout around. We have ordered a new one so if it is a normal relay I can try it in various sockets.
Thanks again
Clive
Clive Turnbull
Cheshire
UK
Old 02-13-2003, 01:03 AM
GFCC
Jeff's Avatar
Clive, There should be 4 relays behind the gauges.
Looking from the driver's window to the center of the car the order is....
1. Power window relay
2. Warning chime relay
3. Windsheild washer relay
4. (this one is located behind #2) Turn signal/ emergency flasher relay.
Jeff
Old 02-13-2003, 08:02 AM
