Member 911 Anonymous
DRACO A5OG's Avatar
Question Strange Deformation on Front Wheel Bearings, WHY???
Okay Fellas,
Happy Christmas and Merry Haunnukkah to all!
So I wanted to adjust my bearings today then "self" said hey re-pack the suckas since you have the fancy re-packing tool, you rarely use. ( I need stop talking to myself )
Okay, took out P-side, Doh! Some of the bearings are gouged . Well, time for a set of new bearings Bye Bye $50, That was fine until I went to the D-side.
Same rusty grease as expected and anticipated gouged bearings. Nope smooth as it should be but wait a minute.
WTD?
(bent at 2:30)
How the heck does this happen? I thought Nippon Steel was the best, I guess not.
No, the allen lock bolt was not loose and torqued to 11ft lbs. Anyone else experience this when all is/was snug?
'85 Carrera Targa
PCA/POC
Old 12-18-2017, 07:16 PM
El Duderino
tirwin's Avatar
Shoosh! No idea but now I want to see how the mystery unravels!
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 12-18-2017, 07:19 PM
DRACO A5OG's Avatar
Well, PSA: Don't just re-adjust the bearings, remove, inspect and or re-pack them.
'85 Carrera Targa
PCA/POC
Old 12-18-2017, 07:25 PM
Looks like you pushed against the bearing cage when you checked the tightness of the washer with a screwdriver.
Old 12-18-2017, 07:26 PM
DRACO A5OG's Avatar
Nope, I use a different technique via Johnson Alignment which does not require the screw driver technique check washer technique.
'85 Carrera Targa
PCA/POC
Old 12-18-2017, 07:28 PM
Who knows, some one may have dropped it on the floor, did not notice, put it in the car. Who knows, the bearing can not talk. Replace it and put it in very carefully. I always thought the screwdriver idea was a little nuts. Tighten it, back off, check it. Check it again in 100 miles. Move on to the next project, lord knows there are many.
My guess is that it was dropped on the floor.
86 Carrara
66 Healey 3000
74 Motto Guzzi
74 Norton Commando 850 sold with a score of Alfas and British and German iron.
Old 12-18-2017, 07:52 PM
Jameel's Avatar
Im doing this on my 83 this week. Care to share the non-screwdriver technique?
Old 12-18-2017, 07:55 PM
DRACO A5OG's Avatar
Johnson's Technique:
Loosen Allen Lock and Bearing Nut a 1/4 turn out
Remove Wheel Cap
Place wheel on hub with 3 lugs
Spin the wheel then at the same time use a BFS and tighten the Bearing Nut quickly
Loosen bearing nut
Do this several times to allow the bearing to seat. After third or fourth tightening, remove wheel
lock the allen
place hub cap on
Install the wheel, do the usual wobble check, wheel should rotate smoothly without binding
Yes, allot more work but my bearings stay snug longer.
'85 Carrera Targa
PCA/POC
Old 12-18-2017, 08:27 PM
Jaskas's Avatar
Bloody hell. I have had similar dents in my bearings. I dont have any idea of the source
Old 12-18-2017, 08:52 PM
DRACO A5OG's Avatar
I have replaced my bearings 4 times, this is the first time I have seen my bearing like this. Strange.
'85 Carrera Targa
PCA/POC
Old 12-18-2017, 09:03 PM
Is just the bottom lip of the cage bent? Any unusual wear on rollers or races? Any pitting?
Old 12-18-2017, 09:27 PM
DRACO A5OG's Avatar
No pitting on bearings or race of the bent cage but the unbent does have pitting on both, crazy right?
'85 Carrera Targa
PCA/POC
Old 12-18-2017, 09:49 PM
DRACO A5OG's Avatar
Lately fronts have been making the proverbial clicks on turns and last minute hard braking
'85 Carrera Targa
PCA/POC
Old 12-18-2017, 09:51 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
That's really weird, Draco, as I have never seen a bent cage on a wheel bearing (aircraft, car or motorcycle) that wasn't dropped on the ground or was in a hub that was mangled from a hard impact.
How does the bearing race in the hub look?
Old 12-18-2017, 10:27 PM
DRACO A5OG's Avatar
The bent cage's race is perfectly smooth as far as I can tell but taking no chances replacing all tomorrow after will call from Pelicans :-)
'85 Carrera Targa
PCA/POC
Old 12-18-2017, 10:31 PM
DRACO A5OG's Avatar
Just read SKF official website: LOL they are blaming me or the shipper/vendor for dropping it or using a hammer upon install or removal.
Funny, none of that happened and I always inspect prior install. But P-side it appears I needed more lube.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0ahUKEwj7sJjXzZXYAhUJllQKHYvHDPAQFghZMAc&url=http%3A%2F%2Fwww.skf.com%2Fbinary%2F81-64875%2F457975.pdf&usg=AOvVaw2PbzHZIDNhVZejk6qUEX6J
Page 47 "CAGE INSPECTION"
'85 Carrera Targa
PCA/POC
Old 12-19-2017, 12:01 AM
proporsche's Avatar
Hi Draco.. i have been using thew screwdriver adjustments since 1985 never ever i had a problem with the adjustments after ...if you do it right....the bearing bent is from the vendor and believe me even sharp eye of yours could miss that;-)
Ivan
Old 12-19-2017, 12:39 AM
Jameel's Avatar
Great reading in that SKF doc. Thanks for posting that Jim!
On your bearing setting procedure, can you elaborate on "Spin the wheel then at the same time use a BFS and tighten the Bearing Nut quickly".
What's a BFS?
Old 12-19-2017, 04:27 AM
T77911S's Avatar
does the bearing still spin freely with the dent?
if so, I would suspect as said above it was put in that way, perhaps dropped.
if it spins, I would not worry about it.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-19-2017, 05:05 AM
bearing
It was dropped in my opinion
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 12-19-2017, 05:15 AM
