-   -   Has anyone refinished their shift stick? (http://forums.pelicanparts.com/porsche-911-technical-forum/980957-has-anyone-refinished-their-shift-stick.html)
toddetch 12-16-2017 04:11 PM
Next month I'm taking out my seats for refurbishing and while they're out I'm going to do some work including installing a new shift coupler and a Seine gate. My shift stick has is scratched up (see pic below), I'm guessing from PO's ring or something over time. Any suggestions on the proper way to prepare and paint the stick while I have it out?
Thanks!
http://forums.pelicanparts.com/uploa...1513469437.JPG
juanbenae 12-16-2017 04:53 PM
if you do the Seine kit right you will be doing some welding lower down on the shaft so id wait it out until that's done. question is how far do you want to go? you could sand and paint it, or take a grinder wire cup wheel to it and strip it completely. really, unless you powder coat it any painting effort might wear off again if you shift off knob at all. the factory coating is hard to replicate wear wise with paint.
remove it after the welding and have the entire thing powder coated. maybe $50?
juanbenae 12-16-2017 04:54 PM
that is a strange wear location to be sure.
Mad Hunt 12-16-2017 05:21 PM
Sorry in advance for the off topic, but where did you get that cup holder?
Ngrich99 12-16-2017 05:22 PM
Cool cup holder. My shifter has almost identical wear, interesting.
Drymartiniwi 12-16-2017 05:55 PM
You don't like the patina?
merlinfe 12-16-2017 06:16 PM
When I did my seine install I sanded down the old paint with 400 then 500 then 1000 grit and shot it with new coat of black satin. Turned out very nice. I ended up adding a wood 917 balsa knob because it gets balls hot here in the summer and burning your hand while driving is no beuno.
-Steve
c2kid 12-16-2017 07:08 PM
shift shaft
+1 on the powder coat, buy an extra shaft (they're common in poor shape, i'll offer one at $35 mailed) and have it redone. no down time and they can do a satin if you like that. cheers, geoff
Canada Kev 12-16-2017 08:10 PM
Yeah, it's probably from a ring. A lot of people shift with their hand on the lever below the knob for the 1-2 and 3-4 shifts. It must be cooler to do it that way I guess...
toddetch 12-16-2017 10:34 PM
@c2kid: I may take you up on that just to have a backup and in case I screw one of them up (and I guess that way I could keep the original with the patina).
@Drymartiniwi: In this case, I'm just not fond of the patina.
@Mad Hunt: https://www.ebay.com/itm/Porsche-911-Cup-Holder-Fits-68-to-98/202128955728
toddetch 12-16-2017 10:36 PM
Oh, and @Mad Hunt, it was very easy to install right on the seat rail and holds something like a Yeti tumbler very well. It has a fairly large hole so if something was pretty small it might jostle around a bit. I could measure the opening tomorrow if you would like.
RocketWrench 12-17-2017 01:50 AM
I once considered taking my gear stick to a saddler to have it covered in leather like this:http://forums.pelicanparts.com/uploa...1513504193.PNG
I changed my mind after considering it might look like an S&M dungeon after that...
Guardsred911 12-17-2017 08:26 AM
Drive it more and wear off the rust! I remember a number of VW's with similar patina that my parents and grandparents had over they years.... except they were shiny steel from use...
Harpo 12-17-2017 08:45 AM
+1 powder coat
jackb911 12-17-2017 08:48 AM
Rustoleum 7777 Satin Black aerosol. Looks factory, wears way better than factory, widely available.
69porsche 12-17-2017 09:30 AM
Porsche 911 Cupholder - Unique Motorcars
Jesse16 12-18-2017 05:41 AM
As a few others mention, I like or maybe just don't mind the "patina" look on that particular part. I've thought about a simple spray paint update but not applied any effort.
My car gets a lot of miles applied normally so stuff is gonna get worn.
4flyboy 12-18-2017 05:50 AM
Sand it and use some POR-15, done. Don't have to remove it and will be far more durable than factory.
That's if you don't think the Rustoleum solution is adequate?
pmax 12-18-2017 11:54 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/799017-painting-metal-engine-shroud-parts-what-paint-use.html
J-Mac 12-19-2017 01:48 PM
Electrical wire shrink tubing. You'll be sorted in <5 minutes.
