Daugaard's Avatar
rear sway bar bushing problem
Hi pelicans.
I bought original bushes for the 18mm sway bar on my SC.
But the bushes have only 15 mm holes, so I ordered another set but the same problem only 15 mm.
The number is 477411313N When i google this number it say 18 mm.
Have others had the same problem?
I also bought new bushings for the front 20 mm and they fit perfectly.
Daugaard
Old 01-18-2018, 01:02 PM
My rears were exactly that way too.
1982 911 Targa, 3.0L ROW with Webers
Old 01-18-2018, 02:45 PM
universeman's Avatar
They're supposed to be like that, at least that is what I found when I researched mine. Squeeze them in and go!
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 01-18-2018, 03:24 PM
Daugaard's Avatar
sway bar
Hello.
I'm not quite comfortable using these 15 mm. I thought there was too much resistance in the sway bar and are afraid that over time they will scream.
I have today bought the old model before 77 'in 18 mm and associated hangers, they fit perfectly but are a little narrower so I have to mount a rubber disk between the sway bar and the bush.
I am most comfortable with this solution.
Thanks to those who have made suggestions.
Daugaard
Old 01-19-2018, 07:23 AM
Looks like a nice solution. Please post your final result so we can judge you mercilessly
Jason - Austin, TX
92 968 coupe
Old 01-19-2018, 11:43 AM
Daugaard's Avatar
Ups, it does not work.
The brackets on SC are not the same as before the 77's
I do not accept to squeeze rubber so much. so I will try to drill the bushing out. maybe a very sharp drill in a lathe.
Daugaard
Old 01-21-2018, 10:44 AM
Mahler9th's Avatar
If you think the ID is too small, you might try opening it up a tad with some sandpaper wrapped around a dowel or other cylindrical object with an appropriate ID.
When I have used these kinds of bushings, I have greased them up with an appropriate product and made sure that the ARB can spin really easily... but my application is racing. I don't want any bind at all.
If I recall correctly, some companies, like perhaps Pparagon Products, sell ARB bushings of alternative materials. I think some of the early versions of alternative materials were developed by Weltmeister and sold by Automotion. If I recall correctly, Dwight Mitchell worked on this with Weltmeister/Automotion. These is another thread on these forums about Dwight and his 911.
Anyway, for the factory rubber bushing, I might try a bit of sandpaper first.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 01-21-2018, 12:31 PM
Betcha can't have just 1
strudelwagon's Avatar
Freeze them before drilling to make life a little easier
SW
87 Carrera Coupe 560kms (Bitza)
74 914 2.0 (Ushi)
2010 GTI (Jackie)
Old 01-21-2018, 12:41 PM
