**** You Porsche, **** You in the Ear!
Metal trim around the rubber seal keeps popping out when I try to place the window in the car. The seal itself doesn't want to fit around into the frame. Yuge gaps everywhere.
I'm so pissed off with this Porsche project.
Local professionals are useless (they refuse to work on old Porsches for this very reason). Yes I"m using Porsche seals and Porsche trim.
Local owners club has not responded to my request for help.
Is there another solution? Way to modernize window installation that does not involve useless trim and crap seals?
I will put a V8 in this Porsche if I don't get help soon!!!
Old 02-10-2018, 02:23 PM
I feel your pain...I just struggled with targa bar seals and was yelling for Elon Musk to launch this car. People here will chime in, I hope, and give you some clues to success. Unfortunately, I can only provide encouragement. Don't give up.
Old 02-10-2018, 02:28 PM
WP0ZZZ's Avatar
This must be the most effective threat to get help in this forum!
Old 02-10-2018, 02:43 PM
Mine is popped out too No ****s given, just gonna drive it.
Old 02-10-2018, 02:51 PM
ZAMIRZ's Avatar
Are you getting help? You really need to have someone pressing firmly and applying force uniformly as you pull the string out from the inside of the seal while in the car. If the metal is even slightly tweaked, it'll pop right out. Before install: Make sure you put the glass on a couple sawhorses, put the seal on, metal strips in and check to make sure it's nice and tight up against the seal. If it's pulling up anywhere, give it 3 or 4 very light taps with a hard plastic hammer starting from where it's flat and moving toward where it's popped out.
Amir
'83 911SC
Old 02-10-2018, 03:46 PM
Checked out
McLovin's Avatar
That trim looks bent.
Old 02-10-2018, 04:20 PM
Be thankful it isn’t a Targa....
Careful what you wish for...
Old 02-10-2018, 06:04 PM
Banned but not out, yet..
RSBob's Avatar
Bought a new OEM Porsche rear window seal for my coupe 2 months ago and unsuccessfully 6 times to get everything to seat correctly. My friend had a 5 year old seal which had never been installed. We compared them and the new one had subtle differences in the corners. We installed the new 5 year old one on the first try with zero drama. Evidently the new seals sold by Porsche are not exact copies and have issues. I would suggest trying some other sources rather than banging your head.
Old 02-10-2018, 07:55 PM
Registered Minimalist
75 911s's Avatar
Has anyone recently installed non Porsche front or rear seals? I’m about to buy both and I’m having second thoughts on the fit of Porsche seals now. Porsche cost so much more.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 02-10-2018, 08:35 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Two choices.. Leave it out, or get a seal from an '89 model. It doesn't use that strip and has a flattened piece made onto the seal that looks similar.
Marc
Old 02-10-2018, 09:11 PM
wayner's Avatar
Doesn’t the metal trim go in AFTER the window and seal is installed ??
SOLD - 914 wide body hot rod
Old 02-10-2018, 09:23 PM
group911@aol.co's Avatar
No.
Find a good used seal. The 964 set up is also an option.
Thanks,
Bob
group911@aol.com
Old 02-10-2018, 09:27 PM
Alan L's Avatar
No the bezel goes in first. But it has to be perfect or near to. What I have done previously with a used one is lay it out on the glass - see how it does not sit perfect and adjust accordingly. Be prepared to spend some time doing this in small increments. The joiner strips go in later.
There are lots of threads about how to tricks to make the job work. But these are not the simplest bits of glass to fit - although I have managed several times.
I once had an insurance fit and the screen popped out partially after about 30 miles into a long trip. Took it to another installer who ordered proper new bezel - the previous installer tried using a generic one.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-10-2018, 11:31 PM
Bland
unclebilly's Avatar
My wife and I have done this numerous times. Be patient and you will get it.
Old 02-11-2018, 04:55 AM
Careful there.
If I am correct the 1989 911s (NOT 964) that used the 964 style seal also had the 964 rear glass, that is about 3-5 mm larger than the 911 glass.
So one might end up with a glass floating in the seal.
Old 02-11-2018, 05:37 AM
I'm in St. Pete also. Go see Micky at Europen Performance and he will help you.
Old 02-11-2018, 05:49 AM
following this as I too had issues with getting a good install of the front windscreen. Very interested in which glass/seal combinations that will work on the SC....
80SC (ex California)
Old 02-11-2018, 06:57 AM
75 911s's Avatar
Careful!
:-) Sorry Jeff!
Old 02-11-2018, 07:28 AM
Chain fence eating turbo
That has undertones of, "hit it with your purse", all over it....
Old 02-11-2018, 07:40 AM
Alan L's Avatar
it's not clear to me how fitting a V8 will fix it. I haven't seen any tips of how-to referring to that solution.
But it does help to have someone following the cord pushing down from the outside to help seat it. But I have generally done mine solo. Not always sucessful first time.
Alan
Old 02-11-2018, 10:08 AM
