Turn signal
Hey guys all turn signals work fine on outside of car but indicator lights in tach don’t, bulbs ok the right bulb will flash on for a second but stops working . Would this possibly be the hazard signal relay or something else
Thanks Mac
82 SC Twin Plug 3.2 SS ,46 PMO
hi..yes it is possible your relay is not good.also check the ground wire to that gauge.
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Could be ground on that gauge. Or light bulb could have fallen loose from the socket.
If flashers externally work, relay is fine.
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
