Looking for a tank that would work for racing.
Insert Tag Line HERE.....
The tanks hold so much oil that baffling really isnt required for even the factory race cars.
Administrator
Corvettes and 996s need baffling. Dry sump systems don't.
------------------ Jack Olsen My Rennlist page • My Pelican Gallery page • My Porsche Owners Gallery page |
Team California
Jack is correctomundo, whole purpose of dry-sump is constant oil pressure in turns.
Platinum Member
My 71 911 would lose oil pressure in hard left corners at track events. At first I thought it was engine/oil pump, but second engine did same thing. Problem went away when I switched to a '74 oil tank.
Schleprock
If the tanks don't need baffling, what's SmartRacing selling below?
http://www.smartracingproducts.com/ProdCat/Oil%20Systems/oilsystems.htm Just asking since I don't know the answer. ------------------ Kevin 87 Carrera coupe |
I have also heard that under braking the oil can slosh forward from the feed and cause damage to the engine. I have heard the 89 911 tanks were the first to be baffled. I am tring to confirm this.
Depending on the g-forces you are intending to generate, the oil tank should have some baffling to prevent oil sloshing around. Violent turns or spins should not result in a ton of oil being sloshed out of the top.
Almost more important than the oil sloshing is the de-aerating the oil. The oil should enter the oil tank on a tangent and have an air/oil seperator device. The factory oil tank is probably not up to the job of a pure race car. You might look in the Carroll Smith books (Tune to Win, Prepare to Win) for the proper design of a dry sump tank. Probably installing the oil tank in the trunk is the best -- it can be tall enought to do allow air/oil seperation and more quantity than the factory system and for a race car you will most likely have a front mounted oil cooler anyhow. Plus it puts weight out front to help balance the car. Here is a picture I found on the net somewhere of a really nice install. Rich PS (Porsche Snobs) -- all racing cars, whether they are European, American or Japanese, have dry sump systems -- even the roundy-rounders. Most of them have nice multi-stage external dry sump pumps that are better than the 911 internal pumps. If you don't have a dry sump system, it's because the rules don't allow it. |
