Swb 911 resistor and relay.
I'm do the wiring properly before I give it a crank to see if it runs. This was on the rear left panel in the engine bay. ( what a mess ) .
Confirming this is the resistor relay ( can't read the Volkswagen part number) and the resistor to run a low voltage to the coil when running. I have an MSD ignition so these are now redundant. Correct.
Thabks Lyndon
Old 02-26-2018, 09:30 PM
