j911brick's Avatar
Originally Posted by Krieger914 View Post
I have access to a 930 torsion tube. It's still attached to the rear floor section though. Is this a better way to do this? Do I get a big hole saw to get that tube off the rear body section?
If you can get a 930 torsion tube that is a better place to start. You can splice it into the old tube pretty easily. You just have to get the angle of the trans mounts right.
Old 10-25-2025, 03:01 PM
Interesting! Those are good reference points as well. Probably need to cut access holes inside the passenger compartment to weld the backside of tube. If could find the correct size tubing I could sleeve both sides.
Andy Brian
Old 10-25-2025, 09:45 PM
j911brick's Avatar
If you cut it in the right place you can you use the leftover material to make sleeves. In my case I just removed and replaced the rear seat pans. Are you on Facebook? I can probably get pictures when I take the pans out again.
Old 10-26-2025, 08:47 AM
j911brick's Avatar
Old 10-26-2025, 04:08 PM
proffighter's Avatar
Maybe I missed something. Is there any question still to answer from my side regarding torsion tube?
Roland
930 Turbo '81 Too many modifications to list
Old 10-27-2025, 06:05 AM
Thank you. I do not have any questions regarding the torsion tube you have.
Andy Brian
Old 10-27-2025, 07:37 AM
j911brick. Thank you for the photos! That install looks good! Is that the jig for the adapter brackets, or did you use them when swapping tubes?
Andy Brian
Old 10-27-2025, 08:03 AM
j911brick's Avatar
The jig is to line up the adapters. More info on my Facebook page. But this is for a G50 torque tube. I also have another pelican page with what I went through.
Old 10-27-2025, 08:34 AM
Ok, wow. I looked at some of the photos on Gruppe 9 You did a lot of work! I may have more questions. ��
Andy Brian
Old 10-27-2025, 11:16 AM
j911brick's Avatar
You should probably call me.
Old 10-27-2025, 03:48 PM
j911brick's Avatar
https://forums.pelicanparts.com/porsche-911-technical-forum/1168629-930-trailing-arms-g50.html
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 10-27-2025, 04:09 PM
Thanks James! I think I will be calling you. I'll. Send you a pm in the next week.
Andy Brian
Old 10-27-2025, 09:49 PM
