I hope someone can help me. My car is an 86 911, I had my gearbox rebuilt, the only thing different is that I had the shop add a quaife diff, the problem is after installing and driving I have a pretty bad tranny leak, the only thing that I can trace it to is the breather, is that possible? I drove the car about 15 mi. and used about 1 quart of oil.
Try to verify that the breather hole is facing towards the tail of the transmission (front of the car). It must face this direction or else it will spit.
Eugene (Formerly) at Pelican Parts Pelican's E-Commerce Guy, 2003-2011 2001 330i Sport 1983 911SC Coupe (sold) |
Any chance the box was overfilled ?
Hey Bill, that was the first thing that I thought of. Tell me if I am wrong but I have always checked the fulid with the car level, if the fluid is at the bottom of the fill hole or if a small amout runs out it is ok.
Irrationally exuberant
Point it forward of forwards but towards the right side a little (1 o'clock). Your profile doesn't indicate your location so I don't know if your driver side is on the right (UK, HK, Aus) or left (everywhere else).
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Hmm... I pointed mine straight back and it doesn't leak up there.
![]() The vent orientation is another possible issue that I hadn't though of.
Re: 915 gearbox
If it's not overfilled and not leaking from the breather plug, another way tranny fluid could get on TOP of the case is by flinging out through the clutch inspection opening up top. This would be indicative of an improperly installed mainshaft seal and would also be evident at the similar opening at the bottom of the case as well. Is your clutch getting wet?
Eugene, Do you know where I could locate a new breather?
Eugene, I hate to tell you but that "ain't " back!
78SC Porsche Targa, 71 911T 86 Mazda RX-7 ITS SCCA racer 05 Porsche Cayenne 05 F350 Powerstroke 90 Miata |
breathers don't break. the ring gear slings oil, which will exit the breather if it's not pointing forward. crawl underneath and reach up top of the trans, and feel for the hole. you can crank it around with a wrench if needed.
Scootr, The only real opening on top of the tranny is that breather hole. The other end of it (inside the case) is kinda shaped like a fountain pen; a tube cut diagonally. I forget which way the open side of the cut actually faces. If the clutch is dry, then the area around the inspection holes will be dry to (yellow arrows). Lastly, the red arrows point to the case gaskets. These can leak even when new, but it would not be a very significant amount of fluid loss. So try to orientate the breather as depicted and see what happens.
Thanks Eugene, I will give it a whirl. Should you be able to blow through the breather rather easily? I can blow through mine without any resistance.
![]() -Chris
