-   -   V-e-r-y W-i-d-e Fuchs for BB2 (http://forums.pelicanparts.com/porsche-911-technical-forum/98952-v-e-r-y-w-i-d-e-fuchs-bb2.html)
Hetmann 02-20-2003 10:24 AM
Same here... I missed the discussion of where you got those.
ZAMIRZ 02-20-2003 11:19 AM
Got lip?
82SC 02-20-2003 11:36 AM
compensating???
hahaha...looks sweet...can't wait to see the car up and about...it is always a treat seeing BB rumble around the wilshire/la cienaga district...
plus then I can get my grubby hands on your leftover parts
MJ
Jack Olsen 02-20-2003 12:13 PM
Thanks.
The 15-inch RSR Wheels are a bear to get tires for. That's why I went with 17-inch diameters. I've got a set of 17x315 BF Goodrich G-Force T/A KD's for them.
The tires are just under 13 inches wide. (That's a lot of compensation. ;) )
http://forums.pelicanparts.com/uploa...elandTires.jpg
The wheels are two piece wheels made by http://forums.pelicanparts.com/Lindsey Racing. They take a 6x16 Fuchs center, and weld it into a single piece rim. The turnaround time is a couple of weeks, if the rim size you need is available from their suppliers.
KTL 02-20-2003 12:20 PM
Thanks Jack.
Dang. I forgot how big those 315's are!!!
By the way, has Lindsey ever mentioned anything about the two "different" 16x6 Fuchs wheels?
One wheel (911 361 113 00, later version) appears a little beefier than the early version (911 362 020 43).
Just curious. Obviously the stronger-seeming wheel would be the wheel of choice. They both weight the same. Well, as best as a fishing or bathroom scale can measure. :p
skinnerd 02-20-2003 12:35 PM
Jack:
I really, really like those wheels you had made up and the gargantuan rubber that will be fitted. I'm with John in liking the satin anodizing, but that's just a cosmetic preference. I respect that the polished look is where you're headed. The choice to keep a "Fuchs" looking wheel on your car is not only applauded, but to be drooled at also. Really cool. :cool: :cool: :cool:
Mikkel 02-20-2003 12:56 PM
AWESOME!
I'm looking forward to seeing the finished car - it will look good for sure.
Adam 02-20-2003 02:11 PM
They're very cool.
What else is happening?
Jack Olsen 02-20-2003 02:16 PM
For perspective, here's the wheel, tire, and a 25-pound dog. ;)
http://forums.pelicanparts.com/uploa...iresandDog.jpg
The shocks are here (from the Netherlands?!) as well.
We're getting close.
speeder 02-20-2003 02:25 PM
LEFTY!! (Or is it Spot)? Whatever, sweet little doggy. :)
Big shoes, BTW. :cool:
Mark Wilson 02-20-2003 02:29 PM
Puppy looks a little intimidated by the wheels.
Don Plumley 02-20-2003 02:32 PM
I guess size does matter.
KevinP73 02-20-2003 02:38 PM
Shame on you Jack. Making the puppy sit there next to all that "unmarked" territory.
baratta930 02-20-2003 05:19 PM
Jack,
What are you running on the front? (wheel and tire size?)
Also are these wheels setup for the same offset as for a 930 application?
Very nice wheels and HUGE tires.
Thanks,
Berardino
84 930
FLAT6FAN 02-20-2003 07:04 PM
Sweet Fuchs.
Texas Turbo 02-20-2003 07:35 PM
Those are simply amazing! http://www.pelicanparts.com/support/smileys/pray.gif I can't wait to see how BB2 turns out, it looks like it is going to be even better than the original.
Mr9146 02-20-2003 09:19 PM
Jack,
Black Beauty is living at TRE right now?
Jack Olsen 02-20-2003 11:15 PM
Yes, it's there for another week. Tyson at TRE has built this car from the ground up, and the attention to detail is pretty phenomenal -- especially when you consider how quickly he's had to do it.
Here are some more pictures from today. Click on any for a larger version.
The motor and tranny are in.
http://forums.pelicanparts.com/uploa...otorTime-T.jpg
Here's one last shot of all the wheels. Note that the fronts, which are 9.5 inches wide, have much more backspacing.
http://forums.pelicanparts.com/uploa...heWheels-T.jpg
This has the inadvertent effect of making them look like normal 7's in front, in spite of the fact that they have 275mm tires. The increased backspacing is part of Tyson's idea for improving the car's handling by minimizing the scrub radius penalty of going to wide front wheels.
http://forums.pelicanparts.com/uploa...lLooking-T.jpg
Jack Olsen 02-20-2003 11:23 PM
Forgot the money shot:
Not much of a picture, but these are the Dutch struts.
http://forums.pelicanparts.com/uploa...Glitters-T.jpg
82SC 02-20-2003 11:33 PM
okay...I've just officially shifted you to my "car crrrraaaazzzie" column
i plan on joining you when I finish school and finally get a paying job...
right now I am in the "starving student restoring a 911 with student loans" column
MJ
