Jumping in feet first... 1970 911T found in San Francisco.
About a month ago I discovered a disassembled but complete 1970 911T in San Francisco that has been in storage since 1992. I'm new here and posted about it HERE.
I had to use a forklift to get it out of the building.
https://www.youtube.com/watch?v=EctW-LPGpL8
I contacted Porsche North America and requested a COA. Thankfully, I've had a little back and forth with them and this is what I've found out so far. Again this is just some of the info from the COA according to Porsche North America.
1970 Porsche 911T (Karmann Coupe)
VIN: 9110121981
Engine: 6106948 (Original)
Engine Type: 911/07
Transmission: 7115686 (Non-original 1971 5-speed)
Transmission Type: 911/01
Exterior Color: 14 - Signal Orange
Interior Color: 11 - Black Leatherette w/Basketweave inlays
Option Group D16:
  • Option Code 1: US Equipment
  • Option Code 2: Blaupunkt Radio 'Frankfurt' (US Band)
  • Option Code 3: Bumper Horns - F/R
  • Option Code 4: Leather Steering Wheel
  • Option Code 5: Tinted Glass All Around
  • Option Code 6: Chrome Whole Disk Wheels 5.5J X 15
Honestly, I wasn't looking for project as I already have a couple going but this was just too good to pass up. So I bought the 911 and put it in the loft at my shop with the intention of storing it until I can complete some other projects first. Well that lasted about a month. This afternoon I pulled the 911 down from the loft and and started on it.
First, I pressure washed it and then started bagging and tagging.
I removed the front and rear seats, all the trim, steering wheel, shifter, windshield, rear side glass, rear glass, headliner, dash pad, interior panels, engine insulation, carpet and carpet padding, and sound deadening. I'm looking forward to getting the COA to see what else is on it especially because of what I found.
I found an air conditioning receiver/dryer in the right front wheel well and an evaporator unit attached to a fan assembly in the trunk. Is this factory AC? If so, everything under the dash is gone. Are the missing parts available?
Are these "S" gauges?
I found a GIANT hole on each side that was covered in cardboard and duct tape. Any idea what went there or why someone would do this???
I found some rust..
I'm still not exactly sure what I'm going to do with the car but because of the rust and the holes I found I'm going to strip the entire car down to metal (soda blasting or chemical dipping). Top to bottom, inside and out. That way I can see the real condition of the unibody structure and determine if any thing needs to be repaired.
I have taken hundreds of pictures, mostly for reference. You can see them here:
https://drive.google.com/drive/folders/1JJ8d91vys-iPgNMWQzr_iu95u5belFV7?usp=sharing
To be continued...
Old 02-07-2018, 01:58 AM
To answer your question--No, that is definitely NOT factory A/C. That passenger side opening under the dash is bubba engineering, as is the blower and associated plumbing in the frunk. The dryer would be located in the driver-side front fender if factory.
Good luck!!!
Old 02-07-2018, 06:40 AM
To clarify: The blower and ducting just under the scuttle is factory, but all that junk in the smugglers' box is home-brewed...
Old 02-07-2018, 06:43 AM
puddy's Avatar
Nice looking project you have there, have fun!
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 02-07-2018, 06:52 AM
Troll Hunter
Passenger side hole sure looks speaker shaped to me. Other side..who knows?
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 02-07-2018, 06:55 AM
Look like speaker holes to me.
Old 02-07-2018, 06:57 AM
agreed. they look like poorly cut holes for 6x9 speakers.
youtube.com/bennyobscene
Old 02-07-2018, 06:59 AM
gptom's Avatar
The AC remains are from a dealer installed unit made by Volkswagen Product Corp
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 02-07-2018, 08:47 AM
If you want to restore the A/C Parts Heaven in Hayward usually has all the interior bits, been there and looked at them.
Old 02-07-2018, 09:07 AM
Good luck!!!
So you got me pretty good on that one, having never heard the term "Bubba Engineering" I Googled it. Not lying.
Thank you.
So I thought the holes were for speakers as well but the holes are way too large for a 6x9 speaker. It looks a monkey cut with a torch!!! I hate people sometimes.
I'm going to have AC in the car. Is this a setup I should stick with or are there better options out there?
Old 02-07-2018, 03:35 PM
So this showed up today... 285HP 3.6 VarioRam w/41k miles.
Old 02-09-2018, 11:29 PM
^ well then,,, this build just got more interesting!!! Get ready to go fast
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 02-09-2018, 11:44 PM
that escalated quickly.
Old 02-10-2018, 07:29 AM
Classic Retrofit: Lightweight Electric Air Conditioning
electric A/C.
Old 02-10-2018, 07:34 AM
Mahler9th's Avatar
Looks like somebody had set that car up for AX at some point. Looks like it has some Schroth ASM belts.
Those have value CPS996.
It was nice to meet you on the phone.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 02-10-2018, 10:18 AM
Quick update 2/19/2018,
I got the original 2.2 apart. Only one head stud gave me trouble. I found 2.2S pistons and (biral) cylinders. The internals look amazing. The crosshatching is still visible in the cylinders. The bearings are dated 1985 and can go right back in. The case was put together with the wrong sealant and was leaking from several places so its headed to the washer.
Going to clean and measure everything and most likely put it back together. I'll install case savers, ARP studs, turbo valve covers, update the oil pump/case, trim the engine air baffles, install Carrera tensioners, send the fan assembly off to flyingjay, rebuilt the Webers, maybe port/polish the heads, and whatever else it recommends in Wayne's book.
Anyone have a really nice std/std 2.7 crank, turbo oil pump or any of the other stuff I'm going to need?
Old 02-19-2018, 05:32 PM
Can I get on your Christmas list. I wish That 3.6 showed up on my door step. Can't wait to see the build.
Old 02-19-2018, 05:37 PM
The 3.6 is completely stock and was in a friend's track car for a few months about 10 years ago and has been sitting since. He told me that it "smokes a little at idle" so it's also coming apart and is going 4.0L and ITBs.
Old 02-19-2018, 06:02 PM
upwardr's Avatar
My 71 signal orange. I look forward to following this thread.
Old 02-19-2018, 07:18 PM
Nice score on the 3.6 from your friend. I'm sure you got a good deal from him.
Old 02-19-2018, 08:04 PM
Tags
1970 , 911t
