-   -   Need a schooling on HE vs Headers for a 3.2 (http://forums.pelicanparts.com/porsche-911-technical-forum/990182-need-schooling-he-vs-headers-3-2-a.html)
tdskip 03-11-2018 07:28 AM
The 3.2 I recently bought did not come with an exhaust system so I have some decisions to make. I am in SoCal, and the car gets used for touring events so it will see weather (that will be pretty modest still, not freezing etc). Car needs to be livable, does not need to pass SMOG.
I was hoping to get a crash course in if headers make a worthwhile difference, if so which ones? Are there HE that are close to the same power and provide heat / defrost? What sizing for a ‘88 3.2? Thick vs thin flange?
Total exhaust newbie here....
Thanks!
billybek 03-11-2018 08:00 AM
Good thread (but $$$$).
http://forums.pelicanparts.com/porsche-911-technical-forum/929207-bigger-ssi-system.html
75 911s 03-11-2018 08:17 AM
For a stock 3.2 you can run original SSI HE. There's data that supports it being a good match. I believe your Carrera will have the shorter studs, so thin flange. Simply measure your studs coming out off the exhaust portion of the heads under the car.
Some clearance issues can develop. I think on the right side header, you may have to dent the heat box on the header to clear the chain box. Sometimes you have to make an adjustment to clear the helper spring on the trans as well.
That's going to be your best bang for the buck imho. If you go bigger with a stock 3.2 you could actually lose power.
If you go aftermarket, there are quality headers like Georges, or cheap chinese headers like QSC. You can get them in any size you need. There are also high end heat exchangers like billy boat and fabspeed.
FWIW I live in Vegas, and I still use my heat all the time for those cool morning runs in winter, late fall and early spring.
tdskip 03-11-2018 08:34 AM
Thanks gentlemen
Jonny H 03-11-2018 09:29 AM
Stay tuned...
New Prototypes in Testing
tdskip 03-11-2018 09:34 AM
Interesting!
Bill Verburg 03-11-2018 01:10 PM
Thanks!
'88 uses the long 30mm studs oe, so thick flange unless you change the studs or pack w/ shims
SSI are only 1 3/8"ID (~35mm)' 1 1/2" OD, this is fine for smaller engines or lower rpm use, they will not flow well enough for full hp at higher rpms. They will enhance torque at lower rpm.
The Eisenmann 42mm SSI copies referenced in the thread above are probably the best currently available for a 3.2 or 3.4
Less money would be B&B or Fabspeed 1 5//8" headers, but it's more difficult to put a good muffler on these.
1 3/4" headers are too big for 3.2
W/ a muffled system you don't get the full benefit of tuned headers anyway so another decent choice might be stock 964 w/ 37mm pipes or 993 which are ~42mm. Again these will be more of an issue to get a decent muffler on.
tdskip 03-11-2018 03:03 PM
Thanks Bill, very helpful.
famoroso 03-12-2018 08:08 PM
Originally Posted by Jonny H (Post 9957050)
For a moment there... I thought you were developing optimal 3.2 headers. ;)
sp_cs 03-12-2018 11:56 PM
JP/Dansk are making 41 or 42mm OD SSIs, tagged as Under Development in their catalogue.
Peter M 03-13-2018 01:38 AM
I think they have been under development for a couple of years at least!
After reading about a million posts, of which about 99% were found to be factually deficient, I ended up ordering a set of http://www.bbexhaust.com/shop/porsche-911-header-with-heat-exchanger-fpor-0401/ with 1 5/8" primaries so I can use a 2 in/1 out Dansk motorsport muffler. I know I will need to use spacers under the exhaust stud nuts since I will continue to use the longer 3.2 exhaust studs. I hope I don't also need to make 20mm spacers to go between the header secondary flanges and the muffler inlet flanges but will if I have to.
From the believable sources it appears the standard 3.2 headers work really well if the muffler and cat are replaced with freer flowing units and are really very competitive with the more expensive street exhaust alternatives on any objective measure.
If you're interested in sound info on 3.2 street systems, suggest you keep your eye out for posts from Steve Wong, Bill Verburg and scarceller. For example: http://forums.pelicanparts.com/porsche-911-technical-forum/635022-what-can-i-expect-3-2-w-exhaust-chip.html
Bill Verburg 03-13-2018 08:00 AM
Those B&B's are new, did you contact them for the sizing info? I can't find it on the site.
Interesting that they don't tout the compatibility w/ stock 911 2 in mufflers, That has always been the major drawback of the B&B headers.
sp_cs 03-13-2018 08:46 AM
B&B and Eisenmann - neither use (or offer?) thick flanges. Are they still deemed required on a 3.2 up?
Bill Verburg 03-13-2018 09:40 AM
No, thin flange can be used on any 911. You just need to either change the studs to shorter ones(likely necessary anyway) or live w/ the long stud shaft prouder than usual
sp_cs 03-13-2018 10:00 AM
Thanks - why do thick flanges exist?
Sorry slight OT
Peter M 03-13-2018 01:07 PM
Bill,
Yes, the BBE site isn't the easiest to navigate and that's why I included a link. I contacted them directly to confirm they were the 1 5/8" primary tube size I wanted. I suspect they have made them for many many years but never promoted them as being suitable for 3.2's because of the flange thickness issue.
I've only found one other on this forum who has installed these on a 3.2 using the generic 2 in muffler and this is the reason why I steered away from their normal 3.2 headers as I didn't want to use their propriety mufflers with the odd spaced 3 bolt mounting flange inlets. He didn't have to use adaptors spacers to fit his muffler so I hope I'm the same.
I will confirm the wisdom of my purchase when they finally turn up and I can trial fit them.
Thanks for your help BTW through your earlier posts on this topic.
Peter M 03-13-2018 01:14 PM
They both offer thick and thin flange options. Usually described as fitting "3.2" and "SC" models respectively on their websites.
The Eisenmanns look the perfect solution but they are eye wateringly expensive where I live and I couldn't find any reliable data on hp gains so shied away from them.
mb911 03-13-2018 02:41 PM
I think this should be noted as going in 914-6 so exhaust options are limited to stock, mine, and b&b and not sure if anyone else is in the game?
I prefer a 1.625 header sizing for a 3.2 engine and stock is 1.5"
Here is a picture of my product.. Just want to make sure correct info is being relayed to the poster.http://forums.pelicanparts.com/uploa...1520977300.jpg
sp_cs 03-13-2018 04:14 PM
Interesting. - I see INd Dist are marketing a 45mm option?
https://ind-distribution.com/product?sku=P91130.WT38
sp_cs 03-13-2018 04:15 PM
The Eisenmann both look thin flange from the pics I’ve seen, certainly not same as ssi thick flange
Bill Verburg 03-13-2018 04:45 PM
45mm is for 3.6 to 3.8
Bill Verburg 03-13-2018 04:50 PM
flanges needed are a function of the stud length
studs were,
20mm on most 3.0
22mm on most 2.4
30mm on 3.2
there are a few oddball 25mm too
You can use thin flange on a long stud, there is just extra stud sticking through
tdskip 03-13-2018 05:15 PM
Thanks guys.
Ben, I was also asking about my options the '74 911.
mb911 03-13-2018 05:16 PM
Originally Posted by tdskip (Post 9960254)
Thanks guys.
Ah gotcha.. In that case 1.5" or stock/ssi is the best bet..
Peter M 03-14-2018 12:55 AM
Ben,
I think the stock 3.2's have 1 5/8" OD primaries and the pre 3.2's like the SC's all have 1 1/2" and this is the reason the stock 3.2 headers out perform SSI's at the top end.
Peter M 03-14-2018 01:00 AM
For completeness we should also mention the nicely made Rarely8 headers with heat exchangers that are nicely matched with equally nicely made M&K mufflers which has to be another front running option for 3.2 owners to consider.
RarlyL8 Headers for Porsche 911
sp_cs 03-14-2018 01:50 AM
studs were,
20mm on most 3.0
22mm on most 2.4
30mm on 3.2
Thanks - so thick flanges were designed for 84-89 cars purely to accommodate longer studs - seems shorter studs would have been more cost effective at the factory.
I had 42mm OD Turbo Thomas headers (thin flange) on mine before and had collars made up to make up the difference in flange depth -headers worked well performance wise but heat was minimal.
My 3.4 has been stroked into a 3540 using a Gt3 crank, so I’m looking at options.
I see PMs have a B&B option with I believe is a bespoke primary length - anyone confirm how this differs to standard B&Bs?
http://www.patrickmotorsports.com/part/1-58-exhaust-manifold-headers-heat-exchanger-set/
mb911 03-14-2018 03:19 AM
Originally Posted by Peter M (Post 9960551)
Ben,
Yes that is correct when I was referring to stock I meant stock 914-6 heat exchangers are 1.5" OD..sorry my bad for not clarifying
Peter M 03-14-2018 03:30 AM
1 5/8" Exhaust Manifold Headers Heat Exchanger Set By Patrick Motorsports Porsche & Mid Engine Performance Specialists
Shirish,
The Patrick Motorsport ones:
are the same as the ones I linked above on the BBE website. However buying directly off BBE will save you around $800 when compared to Patricks. They both have the same part number.
As for the different flange thicknesses, there is only 1/8" difference between the thin flanged BBE's and the thick flanged ones. 3/8" vs 1/2"
Peter M 03-14-2018 05:03 AM
Shirish,
You are correct that the Eisenmann's are only thin flanged but those that have posted have not reported problems with fitting these to the longer stud 3.2's.
Sorry my earlier statement was unintentionally general and misleading about the Eisenmann's
Bill Verburg 03-14-2018 05:09 AM
w/ bigger displacement and more revs a larger tube is indicated, the 45s are probably more appropriate for you
Honestly the flange thickness and the sleeves on some are not worth worrying about
RarlyL8 03-14-2018 07:12 AM
Thank you Peter. Our systems were designed for track cars with heater boxes that are removable. In an off road excursion the heater boxes need to be sacrificial and able to be replaced when damaged or removed when not needed. All of our products are 321 stainless which is much more robust and heat tolerant than standard 304. We have turbo systems that have been in service on track cars for 10 years, no other competitor comes close to that type of durability. We also use F1 merge collectors that are polished internally, no stamped junk with slag on the inside or a big hole where the merge should be. The primary length is not optimized for street engines but these headers perform every bit as good on a stock Carrera as the best street headers out there at our price point.
Tippy 03-14-2018 08:18 AM
Brian, your muffler alone made me want an SC just by the sound.
One of the best tones I've ever heard in a car, and I usually prefer V8 tones.
sp_cs 03-14-2018 10:14 AM
Originally Posted by Peter M (Post 9960601)
Shirish,
No probs at all, thought I was missing something :)
From Bills feedback doesn’t sound as though that it will be an issue.
sp_cs 03-14-2018 03:02 PM
Cargraphic do some bigger ssi too
http://www.cargraphicts.com/en/products/exhaust-systems/for-porsche/911-models/911/911-30sc-g-models/id40-heat-exchanger-based/
Peter M 03-15-2018 12:37 AM
Be interesting to know what they are worth and to see some independent dyno verification of the "up to 20ps" claim.
Nux 03-15-2018 05:49 AM
Old wisdom, originally posted by Steve (Rennsport) from years of dyno testing:
http://forums.pelicanparts.com/uploa...1521118090.jpg
Peter M 03-16-2018 12:17 AM
Nux,
That's actually from Steve Wong who as far back as 2011 posted that the table wasn't flawless:
Guys, thanks for the interest. Since that chart was originally created, there would be further changes I would make to it and would prefer that that one shown should be deleted for the sake of accuracy.
With regards to exhaust mods, in all honesty the stock exhaust is actually very good and the best bang for the buck is a euro style premuffler in place of the cat for additional power. SSIs/early style heat exchangers are small for the 3.2 motor and I don't think it will make any additional peak HP over the stock exhaust/premuffler combo. Stock primaries are 1 5/8" diameter and SSIs are 1.5". If you really want to make more power over the stock exhaust with headers, you need to go at least 1 5/8", which can be from European George, SCARGO, Fabspeed, B&B, Bursch, etc. What the smaller primaries will net you is a 10 hp/10 ft-lb torque gain at 3500 which increases the midrange throttle response giving the feel of more power.
Case in point: Several 3.4 and 3.5 conversions in the past couple of years built by some of California's best engine builders were put on a dyno and live mapped for maximum power. All pretty much had the same wammy mods including cams and ExtrudeHoning, etc. On the 3.4s with a completely stock exhaust including muffler but with either a M&K premuffler or sport cat, the engine delivered over 230 rwhp on a Dynojet. On the converse, the ones with SSIs struggled to get past 220 to 221 rwhp, even removing the muffler and putting on megaphones as a test. With each change a quick AFR remap was performed to ensure the differences was not from unmatched fueling. A 3.5 I recently mapped with all the cost no object tricks but with SSIs could only achieve 233 rwhp, yet others in the past with such as 1 5/8" European George headers achieved around 245-247 rwhp.
On a 3.2 with various mods and SSIs and the stock early Bischoff single out muffler, live mapped and optimized achieved a max of 208.5 rwhp. Removing the muffler and installing megaphones and remapping to optimum AFR achieved 210.5 rwhp. The only area of any notable gain was around 6700 rpm with a 8 hp gain from the megaphones. Very interesting as it tells you the stock early muffler is actually very good. All this was done on the same day on the same dyno for 91 octane California pump gas. Later the exhaust was replaced with SCARGO 1 5/8" headers and a muffler, and the same motor made on the same dyno 218-219 rwhp.
As I said earlier, it is so hard to get good data on 3.2 modifications!
Nux 03-16-2018 12:37 AM
Originally Posted by Peter M (Post 9963068)
Nux,
Ah yes sorry, bad memory. So many cool Steve's out there :cool:
I think Wong's table is good for a rough overview. As you note above, the difference between SSI and premufler is perhaps negligible - which the table also shows.
Bill Verburg 03-16-2018 07:34 AM
There are many variables involved in determining what exhaust to use
Big factors are
engine displacement - typically 2.0 to 4.0 L
rev range - typically 4500 - 9000
muffled/non
stock smog cams/happy cams
gearing including wheel and tire effects
w/ a muffled, stock 3.2 which most users here use the data shows that a stock euro premuffler as the 930/10 SC or 930/20 Carrera 3.2 flows well enough to compete w/ more traditionally headers designs. The reason is 3 fold, 1) sizing is adequate, 2) stock cams don't allow exhaust tuning to work to full advantage 3) any muffled system is going to inhibit flow and exhaust tuning
Here's is an SC premufler
http://forums.pelicanparts.com/uploa...1521210125.jpg
And a later 3.2 Carrera prefmuffler
Small things like the different taper angles, step, transitions and internal structure all affect flow, these factors also affect tube header design and efficiency but the muffler is still the biggest potential impediment to flow.
tube headers will never be able to reach their full potential for enhancing performance in any muffled system because the tuning waves are disrupted so much by the mere presence of a muffler, smog cams will always fail, to allow for the best scavenging efficiency that headers potentially provide. As a result flow is the name of the game in these systems.
