Trailing arm Issues WTF
So I have a problem i just cant get my head around. I have 20mm spacer on the rear left and nothing on the right. but the 20mm on the lest is required to keep my fitment even. I measured from gearbox to axle mounts and the distance is the same so wtf is going on look how close the rotor is to the right wheel compared to the left. The thing thats got me baffled is the alxe distances are the same
Then the wheel offset must be different. Have you put a rear tyre on a wheel from the front?
1983 RHD SC 3.0 1994 RHD E31 850 CSi |
It's a 914 ...
Perhaps to keep tire/wheel clearance looking the same on both sides to account for small differences due to alignment or asymmetry in bodywork? 20mm is a lot though, almost an inch! Has the car ever had crash damage/repairs?
if you are measuring the wheels in relation to the fenders and each side is different, that is normal.
I think I did different spacers on each side for my 77 widebody or I was seriously considering it just for aesthetics.
Could it have anything to do with the non Porsche engine that's installed? Did you keep the 915?
""Has the car ever had crash damage/repairs?""
Bent trailing arm?? seems unlikely but maybe?
1979 SC 1986 Carrera 3.6 L+ |
We have 2 Porsches that are not the same on both rear sides, a 2002 Boxster and 1978 911 SC . . . We use different size spacers to correct the wheel/tire placement . . . not a problem. I would suggest to use your 20MM spacer and not worry about it . Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
Registered Minimalist
First off, I've been following your project build for a while and kudos to getting to this point.
There are a lot of factors involved in your spacing issue. The first that comes to mind is possibly different offset wheels. Swap them and check if there is any difference. The second is your addon fenders. Didn't you recently put wide fenders on the back? Are they square and in the same position? Another thing you might check is a broken TB. I saw a recent thread about this exact problem on the FB page and in several cases, it turned out to be a broken Torsion bar. I don't why or how that would affect the spacing, but something to check. Keep us posted.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
These were my initial thoughts but no evidence of any repairs and we recently did all the floor pan measurements before we made the engine cradle and it was spot on. could one be a turbo arm?? |
There are several different arms out there.. I think they have casting numbers stamped in them. Turbo are different and SWB arms..also steel vs aluminum.
I read on another thread the bending tolerance is minuscule. So if it is a bent arm, it wouldn't be anywhere near 20mm. I think the tolerance is like 3mm before a crack or break on an aluminum arm. (con't quote me on that, but my point is, they don't bend much) You also might just disassemble both sides fully and re-assemble. Everything down to pulling off the spring plates and pulling out the tb.
i will say it again, if you are measuring from the wheel to the fender lip, it WILL BE different from side to side.
with the spacer on the left, the wheel will be further form the rotor although looking at the right I don't remember my wheels being that far from the rotors. do you have custom wheels with more offset?
Insert Tag Line HERE.....
Have you swapped wheels from left to right and see what happens to the measurements at that point?
Marc |
Alignment could affect the spacing. You might have some significant thrust offset.
-Andy
72 Carrera RS replica, Spec 911 racer |
