MFI RSR Pump
Found this on my old 911 project...
Donīt worry, I know itīs special but can someone tell me what makes it so special?
Old 05-14-2013, 03:50 AM
LakeCleElum's Avatar
Price an early RSR and then realize a lot of these induction systems were replaced, lost or broken many years ago.....UnObtainium......
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 05-14-2013, 04:01 AM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
RSR = "special"
Old 05-14-2013, 04:02 AM
Since I have been asked for better pics of the RSR pump...
Voila!
Does anybody know how many of these were made?
Old 05-21-2013, 04:28 AM
tazzieman's Avatar
"Swedish made performance enhancer" , what a nice piece of equipment Mr Powers!
What I'd like to know is how many variations there are for other makes and applications. Why MFI for Classic Porsche? And when did they stop using them in planes? Or maybe they still do?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 05-21-2013, 04:43 AM
The BergMeister
Spyder22's Avatar
This combination looks like the high butterfly and RSR pump combination as used on an RSR in 1973/1974. The single ignition distributor has little to do with this set. If all this came from the same block I would be curious to know what the size of the intake port side of the manifold is? The red intake trumpets and filter housing is something I have only seen once before: on a prototype car....
Leonard Stolk
R Gruppe#600
1971 911 S/T 2.7
1973 911S/RSR
1974 911 RSR
Old 05-21-2013, 05:53 AM
gearhead
You could buy a nice 911T driver for what that would sell for to an RSR owner...
Old 05-21-2013, 06:19 AM
Mr9146's Avatar
It looks like it was equipped with an SCRS air cleaner ... short horns inside troughs that accept a stock MFI air cleaner top.
Good score.
Old 05-21-2013, 08:14 AM
Leonard,
you are correct, well almost.
The engine was originally built by Roitmayer for some tall skinny German Rally driver called Walter something as twin spark but the car was sold and the rules changed to Group 4 which didn't allow twin sparks so it was converted to single ignition. Any more info on the prototype?
Old 05-21-2013, 08:30 AM
356RS's Avatar
Should be a 1974 3.0 RSR engine. The V1077 pump should also have the V109 space cam. The 2.8 RSR had the V94 space cam.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-21-2013, 09:36 AM
OK..........This is a good example where a fella can use the word "Rare", a few times.
1973 911 T MFI Coupe, Aubergine
Old 05-21-2013, 03:57 PM
911 rookie
76_rookie's Avatar
Sorry but I'm having a "hard-on" moment.... there is an old ad on EarlyS for the similar RSR pump for 10K.
Old 05-21-2013, 04:04 PM
Shaun @ Tru6's Avatar
Good score.
Is this filter housing essentially a standard MFI version with the snorkle replaced by a simple screen? Can you cut the snorkle off and add to screen to replicate it?
Tru6 Restoration & Design
Old 03-16-2018, 07:36 PM
that filter arrangement was only used on an SCRS but with a Kugelfischer injection
you can sell the RSR pump and High butterfly to someone like Kevin Jeannette who probably has some cars who deserve it.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-16-2018, 08:41 PM
cnielsen's Avatar
Shaun,
Yes, that is what I did. Shoot me a text tomorrow and I will send you some pics
Beautiful MFI setup by the way!
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 03-16-2018, 09:01 PM
356RS's Avatar
Shaun,
I built something similar with the plastic filter housing for my high butterfly system.
Mark Jung
Bend, OR
MFI Werks.com
Old 03-17-2018, 07:44 AM
GaryR's Avatar
Send a message via ICQ to GaryR
OMG that engine ^^^ is art!
Gary R.
Old 03-17-2018, 08:19 AM
Originally Posted by 356RS View Post
Shaun,
Thanks Mark, gorgeous engine! I'm doing a batch of nickel next week but haven't decided which color to Cerakote the pump. I'm considering a lighter color pump and black zinc chromate hardware but I think it might be too reverse video high contrast. Hoping to get it done and everything back to you by the end of the week.
Did you use Turbo tensioners with collars?
Old 03-17-2018, 05:12 PM
356RS's Avatar
Yes turbo tensioners but lots of new chain & I.S. gears left very little room for the collars on the tensioner plunger. I will most likely have more room in a thousand miles or so.
Mark Jung
Bend, OR
MFI Werks.com
Old 03-18-2018, 08:05 AM
No the scrs are improved and different that they are larger near the bellmouth openings of the stacks. You want them larger in the area to slow in the intake charge down to build pressure where the old ones are constricting.
Old 03-18-2018, 08:49 AM
