Can I use 964 AC control on '87 911?
I have a 1987 911 that has been backdated to a '70's RS. Engine,trans, body, and suspension are done and now I am starting to work on the interior. i want to remove the center console from my 1987 911 and was hoping to move the AC controls to the dash by using a 964 control unit. Is that possible?
Totally different system.
The A/C controls that you have are just some basic switches and wires, you can extend the wires and move the controls anywhere. I put mine into a radio blanking plate. all you need is some room behind the dash and 2 holes about 1/2 inch in diameter each.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Get the Class Retrofit A/C and forgetaboutit!
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
