Tire size question
I have 225/50/16 in the back on 8J16.
Some say that 245 will work, is it really the case?
Here is how the car looks now with 225.
1974 911 coupe 4 speed
Old 03-20-2018, 05:31 PM
MARISOL78sc's Avatar
Bill V. I am sure will chime in but it may be close. That fitment is no problem for an SC. I will defer to Bill on your 76
Paul
2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951
1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold
Instagram: @rennsport98
Old 03-20-2018, 05:41 PM
SC flares were installed on mine sometimes in the 80s.
Old 03-20-2018, 06:15 PM
245's will work if in SC spec....my 78 had troubles with the 205 up front 245 in back should have plenty...
Paul
Old 03-20-2018, 06:20 PM
That’s exactly what I want
Are your rims 8J16?
Old 03-20-2018, 06:39 PM
Under the radar
Trackrash's Avatar
Yea, 245s fit.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-20-2018, 06:40 PM
I run 16x 9 in the back
Paul
Old 03-20-2018, 06:55 PM
Ok, thank you.
It sounds like 245 with 8j16 should be fine.
Wish someone with the exact setup to confirm.
Old 03-21-2018, 05:17 AM
Flojo's Avatar
exactly. a must for 245s
SC needs camber -1°
but 225 on 8s are just fine
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-21-2018, 05:19 AM
Bill Verburg's Avatar
Originally Posted by kavadarci View Post
Ok, thank you.
While there is some variability w/ add on SC/Carrera fares you should have no issues w/ 245/45 x16 on 8ET10.6
The preferred wheel is a 9ET15 though
BTW the J part just describes the wheel profile and is generally not important wrt the usual wheels we use.
diameter, width and ET are what are important
Bill Verburg
Old 03-21-2018, 06:45 AM
Flojo's Avatar
in Germany the Porsche spec guidline for TüV is 9x16.
No chance to get passed with 8x16 with 245s
Old 03-21-2018, 08:29 AM
Most people go by the tire manufacturers spec
for 245/45 x16 that is 7.5" to 9" for most of the lines I know of,
TüV is it's own speciaal case
Bill Verburg
Old 03-21-2018, 10:57 AM
Is anyone running 225/55/16 on the rear tires of the SC ? 8" rim width.
I'm getting ready to replace my worn 225/50/16's and thought the increased sidewall height
might be a better fit. thanks
Old 03-23-2018, 04:53 AM
Flojo's Avatar
well, in this case, it's not a TüV-thing, it's the Porsche spec published: it won't allow 245/45 with any other rim than the 9x16.
And honestly I'd only want it that way, as the wider tire just sits better on the wider rim.
But hey, if you guys can pass a 245 on an 8", go ahead.
the '55 will slightly "baloon" the tire. and it may rub now when it did not before.
plus, what that does to drivefeel I can only guess.. more wobly?
Just get new 225/50.
Old 03-23-2018, 05:01 AM
Hard to believe that Porsche wouldn't follow manufacturers spec. I did look through alkl of the Porsche published data wrt wheel/tire. No such statement.
Please document your claim, otherwise it needs to be filed under more false news
Bill Verburg
Old 03-23-2018, 06:23 AM
Here is a recommendation from Porsche dated 3/16
https://www.porsche.com/usa/accessoriesandservices/classic/tyreapproval/
Paul
Old 03-23-2018, 06:52 AM
Flojo's Avatar
Hey Bill, Paul just postet the link above to the Porsche-List I am refering to.
This is what TüV relates to.
there is the 9x16 listet with 245, the only combination of that sort (9x15 is not listet, but this passes TüV too).
But no chance for 245s on 8x15/8x16.
USA may handle this different.
Old 03-23-2018, 07:00 AM
Those are just the tires that Porsche used when the cars were new, It says nothing at all about other wheel/tire combinations the only admonition is to use an N spec of the same make and type and speed index, This is pretty silly as tire availability is a very nebulous area, they come and go at the tire manufacturers whim For instance there is not a single tire type that was oe on say '86 Carrera that is now available. Sizes yes, updated N spec yes.
The ultimate authority is the tire manufacturers spec, Though I can certainly imagine local authorities insisting that only original equipment specs be used to pass local regulations.
In the US not even the tire manufacturer's specs are looked at very carefully, I don't live in Canada but do believe that the situation there is the same as in the US
Bill Verburg
Old 03-23-2018, 07:47 AM
for reference, here is a 245/45-16 on an 8x16 on my 914...
1971 914-6 GT 3.6
1974 911
1976 911S leaf green backdate 3.2
Old 03-23-2018, 08:39 AM
