7783911's Avatar
Thank you all
Old 03-28-2018, 02:50 PM
Kind of Blue
MrBonus's Avatar
This is my $8 Amazon solution:
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 03-31-2018, 04:52 AM
HarryD's Avatar
My solution. Wired to the switched power to my radio.
Originally Posted by HarryD View Post
I wanted a wired in voltmeter and put the meter here:
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-31-2018, 04:38 PM
7783911's Avatar
I hate that i didnt install the radio so I need to confirm what wire i would use from its massive bundle (theres a small amp under the dash too)
At this points..circuit choices appear
run from radio
run from ignition
run from fuse box
some one suggested clock but that always on so would i just double the battery drain running a voltmeter when no one is is the car :-)
Old 03-31-2018, 05:45 PM
