Thank you all
Kind of Blue
This is my $8 Amazon solution:
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
My solution. Wired to the switched power to my radio.
I hate that i didnt install the radio so I need to confirm what wire i would use from its massive bundle (theres a small amp under the dash too)
At this points..circuit choices appear run from radio run from ignition run from fuse box some one suggested clock but that always on so would i just double the battery drain running a voltmeter when no one is is the car :-) |
