Lazy tire question
Hi I have a 1976 911 and want to replace the space saver tire with a 16 Fuchs rim/ tire. I was wondering if it wound fit. I’m too lazy to jack my car take off the tire and check myself....thanks dave
Old 03-24-2018, 05:31 PM
Will not. You can put in a gas tank from an earlier car and you can then have a full size spare. However, there may be size limitations. I'm sure someone will weigh in. Also, doing this reduces your fuel capacity.
Old 03-24-2018, 05:38 PM
What's the possibility of having the collapsible spare tire mounted onto a Fuchs rim? Does anybody do that?
76 911S
Land Rover 110 Defender
Old 03-24-2018, 06:24 PM
Rescuer of old cars
Arne2's Avatar
The 15” collapsible will fit on a 15x6 Fuchs. Pretty expensive spare.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 03-24-2018, 06:58 PM
Registered Minimalist
75 911s's Avatar
Thought about this too. That steelie is a heavy mofo...
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 03-25-2018, 06:40 AM
Cars and Cappuccino
tdw28210's Avatar
Had to find an old school tire shop to get it mounted. Big tire chains won't likely do it.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 03-25-2018, 05:53 PM
BlueWing's Avatar
Besides the safety factor of the spare up there is the additional "ballast" good to balance the front to rear ratio. A case of where weight benefits handling?
I don't know just speculating. And if lightening the front will not impact too much how about an alloy from an different application. Does VW, Audi or MB use the 130mm lug spacing and offset?
Terry
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 03-25-2018, 06:23 PM
FYI, The 928 S4 came stock with an aluminum rimmed colapsable spare.
Old 03-26-2018, 11:00 AM
Eng-o-neer
Tremelune's Avatar
What are your goals? Better looking frunk? Weight reduction?
From all I've read, keeping weight in the front to "balance" the rear moves in the wrong direction. Having less seems to just be better.
Old 03-26-2018, 02:56 PM
Are they glued on or mounted like a normal tire?
76 911S
Old 03-26-2018, 10:29 PM
Cars and Cappuccino
tdw28210's Avatar
Mounted. Looks pretty wild when they put the air to it. Like an alien erupting.
Old 03-27-2018, 02:27 AM
safe's Avatar
If weight is an issue, try the later spares that's on aluminium rims, I think you can find them in both 15 and 16 inch.
I really think its the tire itself that's heavy.
Magnus
Old 03-27-2018, 02:50 AM
any sense of what the steel wheel itself weighs? 75 911s (duane's) post above shows just over 45 pounds for the combo of the wheel, tire, jack, toolkit and another container sitting inside of the steel wheel. Would be interesting to see the actual weight difference between a the steely, a 15x7" fuchs, a 928s4 spare, etc.
Old 03-27-2018, 05:18 AM
PRE-H20's Avatar
I did the spare tire on a Fuch and love the look.......
AAA card in wallet.
Old 03-29-2018, 12:45 PM
