LinkBack | Thread Tools | Rate Thread |
Is there a way to check if an engine is sealed up properly before installing?
I would assume running it on a dyno would be a logical move but is there something that can be done BEFORE or in lieu of dyno testing to ensure case halves/ other areas of leaking sealed properly?
1980 911SC Targa 3.6L |
PRO Motorsports
No.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Engine test stand.........
I run my engines on an engine test prior to installation in the car. After the test run, all you need is bolt the motor back and drive the car.
![]() Tony |
The 9 Store
test stand
All used parts sold as is. |
Banned
if a newly sealed motor is leaking you have bigger problems than another motor drop....
I have a tendency to get distracted and might end up missing one of the places that needs to be tightened.
1987 Porsche 911 Carrera Coupe |
tony does enough rebuilds a test stand is worth while. also a requirement if you build an engine and ship it and let the owner install it. just put it in.
and that's my issue the build is in another state and being shipped back to me
Why send it to the builder you obviously not trust in the first place??
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Chain fence eating turbo
Case through bolts with oil around them, many seals, JB Weld covered studs, lots of aluminum or aluminum mating surfaces, etc. These motors remind of old Chevy V8's, they leak like sieves unless you've been building them for a long time and know what to look out for.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
