RS carpet help
Well just started already a little trouble, so what’s the secret, I can’t get this rear seat screw to move any, this is a pic, the other side doesn’t look so well since I have been pounding on it
Thanks for any advice before I cut it off
82 SC Twin Plug 3.2 SS ,46 PMO
Old 04-05-2018, 09:41 AM
That can be tough one! The trick I used was to turn a large screw driver with vice grips.
1982 911 Targa, 3.0L ROW with Webers
Old 04-05-2018, 09:44 AM
I would rather be driving
jpnovak's Avatar
impact screwdriver. large bit. Hit with hammer so that the bit seats and the cam turns. Should break it loose.
Old 04-05-2018, 09:57 AM
Oh I did even used a socket with screw driver head, nada, just tried using a small flat chisel to hit one side of the screw slot to get it to break nada. Starting to think cut it off with Dremal
Old 04-05-2018, 10:01 AM
GOM (Grumpy Old Man)
Busta Rib's Avatar
It will come off but you need a large bit and driver with some leverage. Something like this: http://a.co/iV2Rkm3
It likely hasn't moved since installed from the factory. It is a PITA, but it will come off. Have patience. Better than cutting it off.
Instagram: @3pedalposse
Old 04-05-2018, 10:17 AM
dos531's Avatar
This. Impact driver will take it off.
https://www.amazon.com/gp/product/B000NPPATS/ref=s9_acsd_top_hd_bw_b2cMYAl_c_x_w?pf_rd_m=ATVPDK IKX0DER&pf_rd_s=merchandised-search-3&pf_rd_r=CA89TSFHDXC7H1ZGZV7P&pf_rd_t=101&pf_rd_p=236e5c50-0504-5ed9-95c7-b4e005249fcf&pf_rd_i=2399141011
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 04-05-2018, 11:01 AM
tobluforu's Avatar
Are throwing away the carpet, if so spray the heck out of it with kroll
Old 04-05-2018, 11:19 AM
I had the same issue last year when removing my seats to pull out the carpet. Impact driver had it off in 1-2 minutes each side. I think mine came in a small kit from Lisle. Well worth the expense.
~Brian
1987 911 Carrera
Old 04-05-2018, 11:24 AM
Thanks to all just ordered that Leslie impact next day Amazon
Little PCar patience , Am I the only one that has developed great deal of patience owning one of these gems
Thanks Again
Old 04-05-2018, 12:28 PM
A large flat blade screwdriver with vice grips is how I always did them.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 04-05-2018, 12:30 PM
(man/dude)
Jonny042's Avatar
Snap-on screw drivers have a hex built into the shaft, near the handle, for this very reason.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-05-2018, 06:48 PM
+1 on the Snap-On
I am doing the rear seat delete and RS Carpet from Appbiz as we speak.
I just sprayed a small amount of PB Blaster on the screws and let it soak overnight. Then using a rubber mallet, tapped on the screw driver and was able to loosen them with a reasonable amount of force.
Here are a couple pics of the snap-on screwdriver where you can hook up the box wrench.
Also, I will have most of a black interior from a 1986 for sale in the marketplace soon. Good shape. Not great.
For those that have done the Rear seat delete, do you recommend taking out sound padding?
The car is an outlaw and is loud as hell already with headers. I’m not concerned with decibels. More concerned with how will the new carpet lay down.
1986 911 Grand Prix White
Old 04-05-2018, 08:30 PM
Huge weight savings with the sound pad removed, but you will have some work to do make it smooth for the carpet.
Old 04-05-2018, 08:57 PM
I like weight savings!
Do you know of any links to threads that detail what goes into the prep work prior to flying carpet?
Old 04-05-2018, 09:34 PM
joefrantz's Avatar
+1 on removing the sound pad from the seat back/pkg shelf, side panels, and wherever else you can. Good weight savings.
Here is an old thread with a good discussion of options for lighter weight 'underlayment' for the RS carpet.
How to install RS carpet and make it look good?
Joe Frantz
73 911 T
Thx Joe and Ayles!
Old 04-05-2018, 09:36 PM
