x-faktory 3.8RS w/ITBs
New project in the house. 964 w/3.8RS built motor..........
We are installing the Rasant GT3 intake (Independent Throttle body EFI with common plenum) and a Rarely8 GT3 exhaust with active valves.......Motec ECU, Weapon-X COPs...all of the good stuff..... Parts are coming in, enough for me to get started, but still waiting for some of the system bits....this should be a fun one. ![]() going from this: ![]() To this: (borrowed a Rasant pic, to illustrate) ![]() regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Wowzas! Second best news I’ve heard all weekend!!
that is awesome al... kill it!
3.8rs
The 964 engine compartment is the proverbial 10 lbs in a 5 lb bag. 1st, you gotta take it all apart.........and remove at least 5 lbs
10lbs 5 lbs regards, al
Good god that is one sexy ass engine. Should sound like a million bux with that exhaust setup
81 SC 3.8 Conversion 2017 Macan S INSTAGRAM @tail_spinz |
Cool build thread. That’s my car!
Hi Al! |
Looking forward to seeing this one
Instagram: @TuitTech |
Racer
Al,
My 3.6L race engine uses a Rasant wiring harness with a WeaponX CoP setup. Make sure you use 2 3-channel ignitor modules per side. You do not want to divide the ignitor output. This is how my setup looks: ![]() Note that I am using these standoffs for the ignitor heat sink plate: https://www.mcmaster.com/93655A262/ And these for the CoP retainers: https://www.mcmaster.com/91407a119 The mounting plate/heatsink is this part: https://www.mcmaster.com/8975K89-8975K866/
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion Last edited by winders; 11-28-2020 at 11:13 PM.. |
Racer
Al,
With the MoTec M130 setup, these are the injectors to get: ID1050-XDS - Injector Dynamics No, they do not flow too much. The MoTec software has these injectors in its injector drop down so the ECU will know their characteristics. I am getting great power and economy with these injectors. Scott
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Beautiful engine Scott........did you build that?
regards, al
tipping point
removing parts is still underway...the rest of the exhaust is next...but for the most part, i am at the point where parts are being installed. The A/C compressor and associated crapola have been removed...to be replaced, at a later date with a new electric A/C system. To ensure that there is enough juice, a new high-output alternator from classic retrofit has been installed....While i was in there I refurbed the fan/housing a bit....Also I've have the new wiring harness pulled through through the bulkhead, into the interior and the COPs ignitors, throttle bellcrank and Vacuum manifold installed....Still looks like a clusta, but will now start to clean up nicely....next week the ITBs should be installed, cam and crank sensors installed, fuel plumbing/wiring should be completed......than all i need are the missing bits...the GT3 plenum (Rasant) and the GT3 exhaust (Rarly8) and then it's tuning time.
regards, al
It looks fantastic. Are you using one lambda probe per engine bank?
📸 https://www.instagram.com/porsche.tech 📸 |
al. that is gorgeous... someday....
That is a pic of Scott Winders very cool 3.6 motor...it is a thing of beauty....
But, that is not the engine I'm working on...however, dual Lamda sensors are being used on my 3.8RS project. regards, al
Racer
No, I did not. William Knight is the architect and Mat Lowrance built it. It is a wonderful engine...369 WHP and 290 WTQ. I received the long block with the ITBs installed. I installed the wiring harness (built by Rasant), the CoP setup including fabricating the mounting plates/heat sinks setup.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion Last edited by winders; 12-05-2020 at 12:13 PM.. |
Racer
Another thing that was surprising is the fuel economy I get. The MoTec M130 is sequential mode is burning quite a bit less fuel than the previous 3.6L race engine in batch mode spinning 800 RPM less and making 100 WHP less.
"The MoTec M130 is phenomenal at keeping the AFR right at the target number."
What is that number if I may ask? |
Racer
That number is .90 lambda unless other conditions (knock, cylinder head temps) cause the ECU to lower it.
I am running 110 or 112 octane race fuel with no more than 20 degrees advance...
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion Last edited by winders; 12-05-2020 at 01:22 PM.. |
The MoTec M130 is sequential mode is burning quite a bit less fuel than the previous 3.6L race engine in batch mode spinning 800 RPM less and making 100 WHP less.[I[/I]
This is an amazing stat.... had no idea motec tuning for non-pro cars could be that sophisticated.... |
