Fibreglass RS rear bumper seal on a SC
Good afternoon All,
I am mounting an EB Motorsports SC RS fibreglass rear bumper and there is a gap in the seal where the bumper bellows would sit previously (on the stock bumper).
Can anyone recommend the seal you have used with a RS rear bumper style from under the rear deflector right to the bumper edge?
Thanks for your help.
Chris
Toronto, Canada
Old 01-12-2016, 01:25 PM
gliding_serpent's Avatar
Subscribing.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 01-12-2016, 02:53 PM
If you are talking about the area forward of the bellows, I reused the factory seal...Part #: 911-503-185-00-M136
1986 3.2 Carrera
Old 01-12-2016, 04:21 PM
Or, if you need a longer area covered, get the 930 bumper welting. #999-911-205-40
1986 3.2 Carrera
Old 01-12-2016, 04:33 PM
BFT3.2's Avatar
..or do you mean here?
I'd like to know myself. The "explanation" I got from the high-end P-car shop that did my bumper was that there really isn't a alternative. Kinda found that hard to believe. A friend of mine has a yellowbird RS bumper but with no seal at all.
______________
'88 911 Coupe
'98 Spec Boxster
'85 380SL Benz -Euro
Old 01-12-2016, 05:02 PM
That is what he means. The issue is (below) the lenses themselves. Others add a bid of generic black rubber or foam.
Getty says that their front bumpers are designed for no seal. I wonder if it is the same for the rear. Here is a quick mockup (with no real effort put into alignment) with my "74 RS" rear bumper from Getty. I will probably put a thin seal around my bumpers as I like the look.
1973 BMW 2002Tii
2016 Ford Focus RS
Old 01-12-2016, 05:17 PM
Thanks all.
The photo of the red car shows exactly the issue.
I would think that there has to be a solution with all of the fibreglass rear bumpers available in the market.
Thanks,
Chris
Old 01-12-2016, 06:09 PM
BFT3.2's Avatar
For reference, mine is a very recent Getty made '74 RS rear
______________
'88 911 Coupe
'98 Spec Boxster
Old 01-12-2016, 08:11 PM
Science is NOT optional
rbogh901's Avatar
Are generic seals a FLAPS item? I need a seal and was considering a single long one to run from flare to flare without piecing it together.
PCA member since 1993
Old 01-12-2016, 08:14 PM
I am not sure what you mean by FLAPS.
My thought was to try a singe piece as you suggest. Thing is, they appear to be designed for a thinner trim piece near the flares. I can probably reuse the factory parts above for each flare, and the red car above seems to have done the same. Then it is just a matter of finding something appropriate for the remainder of the gap, which will need to be thicker. So I think without going custom rubber with variable thickness, it needs to be three piece.
1973 BMW 2002Tii
2016 Ford Focus RS
Old 01-12-2016, 08:33 PM
Friendly Local Auto Parts Store = FLAPS.
Old 01-12-2016, 10:33 PM
Senior Advisor
James Brown's Avatar
i used soft ¼" tubing like vacuum tubing, just lower the bumper and place it in there and squeeze it down, looked good as factory
08 Cayenne Turbo
Old 01-12-2016, 11:59 PM
moneymanager's Avatar
This is my non-flared 74 with Getty bumper and the trim strip I got from Peter. The strip actually extends another foot or so, must be cut to fit. But any generic rubber molding will do a fine job.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 01-13-2016, 11:49 AM
CPT KAOS
LeftCoastErik's Avatar
Call Peter at Rennspeed in SoCal, he has a gasket that works perfectly that he sells with his RS/Iroc rear bumper. Just used one on mine.
Erik- RGruppe #743
Sports Purpose Garage
CPTKAOS 313HP/265TQ(wheels)2150#
Old 01-13-2016, 12:02 PM
Dave over @ TRE has extended gaskets, I picked up a front RSR gasket that is an extra 3" long to accommodate flares from him.
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 01-13-2016, 12:19 PM
Same color as me. Any full car photos?
1973 BMW 2002Tii
2016 Ford Focus RS
Old 01-13-2016, 12:55 PM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
I have to get one as well for my project... subscribed.
I used some generic flat rubber trim for the rear bumper on the sides... but still need to find something for the rear/center section.
If someone can identify (brand, link, etc.) and share... something idiot proof ...
For the front, I used the 964 rubber trim. To me that looks like the best finish for the RS bumper.
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 01-13-2016, 01:01 PM
Cars and Cappuccino
tdw28210's Avatar
Going through this now we my RSR-inspired hot rod project. We are using the Rennspeed extended seal and then modified the rear light holders slightly to continue the edge that appears to end too early thereby not securely holding the body to bumper seal firmly.
I looked at at a high quality RSR build that appears to have followed the same path.
Old 01-13-2016, 01:53 PM
wachuko's Avatar
On the sides, we used a very thin gasket... see the photos. Left over from the RSR project.
Drive safe!
1967 - Porsche 912
Old 01-13-2016, 02:01 PM
Cars and Cappuccino
tdw28210's Avatar
Dream,
Wachuko's solution is probably your best bet as it looks like it gets installed post paint and panel fitment.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 01-14-2016, 03:09 PM
