Did I end up with suv 911
Hi,
Car has been in the air on the torsion bars for few months. Oem shocks were gone and new koni sport installed .
After putting the car down I am shocked at how high it sits. I did noticed it starting to come down slowly as the koni sport are quite firm compared to the old ones.
It needs to be driven and might settle but I’d this normal?
I’m putting a photo before and after.
1974 911 coupe 4 speed
Old 04-13-2018, 02:43 PM
TheSt|G's Avatar
Takes a bit for things to settle post suspension work. Get out there and cane it a bit on the back roads and report back.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 04-13-2018, 03:36 PM
Yep - Kinda normal.
Old 04-13-2018, 03:47 PM
Eric at Pelican Parts's Avatar
It took my suspension about a week to start settling in. Give it a hundred miles or so!
23 Macan GTS
97 240SX
94 Land Cruiser
Too many Miata's to count.
Old 04-13-2018, 03:59 PM
Koni gas in the rear are way too stiff. I installed some a while ago, went for a ride and felt like I was looking down on the road due to the rear being so high and stiff. Returned them and went with Bilstein HD.
206 637 4071
Old 04-13-2018, 04:42 PM
Thank you.
I don’t care about the stiffness as long as it settles down.
It already dropped 4cm by just sitting in the garage, was 74 before now 70cm.
I still have tons of work to do on it so it wouldn’t be on the road for a while.
Old 04-13-2018, 04:51 PM
When lowering from a lift the outside of the 4 tires hit first due to how they hang. You hear the rubber skipping a little bit as it continues to lower and bears more weight but it’s still off until you drive or roll it back-and-forth a few times to let the tires release the tension and sit flat on the treads
if you roll it back and forth a few times it will come down a lot.
Old 04-13-2018, 07:30 PM
Will do that, and makes sense.
Thank you.
Old 04-14-2018, 06:46 AM
El Duderino
tirwin's Avatar
Another trick is to open the doors and stand on the door sill and bounce up and down a few times.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-14-2018, 07:10 AM
Awesome thread Karvadarci, I am doing the same shock replacement on my 86 911 which happens to be the same color Targa. While there, the sound deadening for the engine turned to dust. A very messy clean up. But more importantly I am replacing the flex brake lines which you may think are ok, but take one off and it is as hard as a stone and can barely flex at all. So as usual one task morphs into another and presto, I have a better car.
Old 04-14-2018, 03:43 PM
cycling has-been
bkreigsr's Avatar
Hate to say it, but that size lift is not going to cure itself. I see a torsion bar indexing in you future.
Did you do a side-by-side length comparison at full extension of new vs old before install?
I was going to do a swap of my old 930 shocks into my 912E and saw the 930's were 3 inches longer.
Bill K
Old 04-15-2018, 05:56 AM
Bill K
Yes, this I must do as the car was too high even with the old shocks.
I did measure and the car was uneven. My guess is someone did torsion bar indexing to raise the car instead of replace the shocks.
I am replacing the front shocks at the same fine, will drive for a little bit and Gen decide how much to lower.
Old 04-15-2018, 06:41 AM
It's a 914 ...
stownsen914's Avatar
Gas shocks can add more spring rate to your car than you'd think, especially if your old shocks were non-gas or just worn out.
Different situation, granted, but when I had my Bilsteins rebuilt, I was surprised to find that my 911 racecar suddenly gained 3/4" of ride height, and I had to redo the setup.
It's possible you're seeing a similar result. If the rear is going to settle with your new shocks, it should do so after your first drive.
Scott
Old 04-15-2018, 06:58 AM
proporsche's Avatar
double ....had to delete it...
1985 911 with original 502 191 miles...808 198 km
Old 04-15-2018, 08:45 AM
proporsche's Avatar
Kava ..you need to readjust your rear spring plates and the front height with the screw.
The rear should have adjustments but i forgot which year is your 911.
here
Adjustable spring plates?
