my new to me 1980 SC
-cardboard shoved in turn signal switch to lock on High Beam, so that shows some issues I know, but question is would it have effect on any of these? 1) no driver front running or turn signal, does have driver maker light 2) neither front turn signals work, rears do 3) no driver side rear brake light, but passenger does work -took all items apart (did find some bad grounds) but can't find anything else wrong -all fuses are wring out good ideas from our fleet of geniuses on PP?? ![]() thanks, Steve
1975 914 1.8l 1979 911SC Targa - In Restoration 1972 Pantera Dune Buggy Dual Port 1835cc 1980 911SC Targa - Driver/Winter Project |
experienced the same
theres some good articles on repairing turn stalk , i would suggest start there...if that doesnt work, you really have to check all grounds..in my case it was the driver parking lamp that was not grounded and created havoc with turn signals working as well as intermittent brake light
let us know what you find :-) |
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
great tips, thanks guys, thread spoke on topic of fuses and contacts needing cleaning maybe
-car did sit for 22 years in humid Georgia, going to check that also, horn only clicks the relay but won't fire
https://www.pelicanparts.com/techarticles/pcar_com/964_horn_repair.htm
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
ok didn't get to the turn signal switch yet, did do some of the fuses and have more items working, found I need a new battery as one in there is too small and has no lower lip to grab the hold down clamp, going to tackle horn next, thanks again to all that helped
did find issue with Right head light, the low and high beam headlight fuse doen't have the wire going to it
does power come into the bottom or the top of the fuse block?
