Oil pressure sensor
Hi,
Since I am fixing the triangle of death, one of the items to replace is the oil pressure sensor with wire attached to it.
I checked few places and all had the same one which I ordered.
After receiving the part I found mine is much larger in the thread area.
Can someone help me identify the correct part number?
Here is a photo with the difference.
1974 911 coupe 4 speed
Old 04-26-2018, 10:39 AM
Administrator
Dmitry at Pelican Parts's Avatar
Give us a call at 888-280-7799 and ask for one of our Porsche part specialists; they'll be able to confirm the correct part number for you.
Old 04-26-2018, 10:49 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The threads for the oil pressure warning light switch are M10x1.0 That's the same threads as brake line tube nuts, so if you have an old brake line you can compare it that way.
The part number for the oil pressure switch is 911.606.230.00
Kevin L
'86 Carrera "Larry"
Old 04-26-2018, 11:58 AM
Those two are the same thread. Maybe you took the adapter fitting off with the switch.
206 637 4071
Old 04-26-2018, 01:18 PM
Is there an adapter?
Everything just came off and I cleaned the sensor. I didn’t see an adapter.
The thred and opening to the engine case is without a doubt in my mind bigger than them he new sensor.
Maybe there was an adapter at one time.
I can take it out again I guess.
Old 04-26-2018, 04:45 PM
Under the radar
Trackrash's Avatar
That is actually the oil pressure warning switch. And yes it threads into an adapter.
MAKE SURE the threads are EXACTLY the same on your old and new units.
Some of the replacements have pipe threads that are very similar to the 10 mm threads that it should have, but will not be correct and leak. AHIK.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-26-2018, 04:56 PM
Ok so I don’t have an adapter then.
Old 04-26-2018, 06:00 PM
The adaptor is in your picture.
Bruce
Old 04-26-2018, 06:22 PM
The one on the right is the one that is currently bolted into the engine case.
The one on the left is what I just received.
If I take the right out the left thread diameter is so tiny that will just sink in.
Not sure if I’m missing something here.
Old 04-26-2018, 06:41 PM
I believe the one on the right is already screwed into an adapter - please see snapshot from the PET below:
Old 04-26-2018, 06:53 PM
You got the right oil pressure switch.........
Kava,
Separate the old pressure switch from the adaptor. You just removed the pressure switch with the adaptor.attached to it. And you have the correct pressure switch.
Tony
Old 04-26-2018, 07:59 PM
This dummy finally got it.
Thank you so much.
I will do that.
Old 04-27-2018, 04:47 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Gordon makes a good point about these threads. For anyone doing a search in the future about thread size and happens across this thread, M10x1.0 and 1/8 inch-27 threads per inch National Pipe Thread (NPT) threads are so very very close in size that you can EASILY mistake one for the other.
The proper switch should be M10x1.0 and needs a tiny aluminum sealing ring to keep it from leaking. It's not a thread interference seal like NPT threads. To prevent oil leakage the switch needs the sealing ring in place to squish between the switch body and the top of the adapter
Kevin L
'86 Carrera "Larry"
Old 04-27-2018, 07:02 AM
And then they still seem leak! One reason they get replaced anytime work is done in the triangle of death.
Old 04-27-2018, 07:16 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Yeah gotta "love" the irony of that. But I think they leak at the plastic-metal crimp joint and not at the threads. Good reason to put a swipe of epoxy around the crimp joint (just like Tony's picture shows for three of the four switches in the top row) when reinstalling a switch
Kevin L
'86 Carrera "Larry"
Old 04-27-2018, 07:39 AM
Look up the torque value for your car for the switch. It's not much. You definitely do not want to over tighten it.
Old 04-27-2018, 08:15 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Spec book say 20 Nm = 15 lb-ft. A bit less than a typical 13mm (M8) nut torque. Just make it nice and snug to squish the sealing washer
Kevin L
'86 Carrera "Larry"
Old 04-27-2018, 08:21 AM
Got it
I will add epoxy as shown, honestly I didn’t notice epoxy until point it.
Great idea ��
Old 04-27-2018, 10:40 AM
Oil pressure switch........
Got it
Great idea ��
Kava,
I just finished the 4th group for the Engine Rebuilding Classes today and one of the things I discussed with the participants was to apply some epoxy bead on top of the oil pressure to prevent unwanted oil leak. My 78 SC had one installed more than 20 years ago and still no sign of oil leak on top of the motor.
Tony
Old 04-27-2018, 05:34 PM
Thank you.
Did apply epoxy and job done.
Old 04-27-2018, 09:42 PM
