Send a message via AIM to tmblackflag Send a message via Yahoo to tmblackflag
Window goes down slowly unless it's warm out
My right window goes down dreadfully slow when it is cool/cold out. If the car sits out in the sun for a bit the window goes down mostly normal but appears still appears to be dragging or catching on something thus slowing it down slightly.
It's just the passenger side - what should i be looking at?
1986 3.2 Meteor Metallic Grey
Old 04-20-2018, 01:59 PM
Administrator
Dmitry at Pelican Parts's Avatar
Take a look at the link below, it may be helpful for you in troubleshooting.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/78-Window_Regulator/78-Window_Regulator.htm
Old 04-20-2018, 02:12 PM
TheSt|G's Avatar
Opening it up will let you know pretty quickly. The window regulators have a clock spring on them with a retention post that likes to break(easily fixed with a bolt), they may need to be greased after 32 years, the rubber seals could be deteriorated, and so on.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 04-20-2018, 03:29 PM
Fleabit peanut monkey
Bob Kontak's Avatar
+1
Clean contacts on switch and put basic grease or your high end lubricant of choice on the big arc thingie with teeth.
1981 911SC Targa
Old 04-20-2018, 05:01 PM
Counterclockwise?
Mine was the channel felt.
Old 04-22-2018, 11:58 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Both regulators on my 86 had the broken clockspring post issue. Time to remove the complete regulator(s), clean off the old hardened grease, check the felts and probably replace the post with previously mentioned bolt fix. I used 1/4"carriage bolts with the rounded head ground down a bit to clear the arm. Just time and it's a dirty job but it will make the world of difference on your window raising speed.
1986 Targa Guards Red
2021 MT09 SP
Old 04-23-2018, 04:25 AM
stevie 77 930's Avatar
Agreed +1
Start with this, it's easier (and cheaper) You don't need to pull the door apart to do this either.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 04-23-2018, 09:02 AM
When my ('84 911 Carrera) window struggled to move up, applying silicone spray (off the shelf automotive store can of silicon spray) to the vertical channels (the felt in the channel, and let it drip down the channel, down below the 'window sill') did the trick. Over time it improved even more. I had this problem, and don't have this problem now, and that is all that was done.
Old 04-23-2018, 01:16 PM
I'm having the same exact problem, except that it works fine when the door is open. If the passenger door is closed, it's very slow. It's been this way for a long time but now it's gotten worse, popping the glass out of the metal holder that grips the bottom of the glass (causing that holder to fall to the bottom of the door and the glass to drop).
I've lubed the felt with silicone but no luck. I have to think the window frame is distorted when the door is closed.
Any ideas?
1986 911 Carrera Coupe
2016 VW Golf R
2008 Toyota Highlander (given to kid)
2021 Kia Telluride
2020 BMW R1250RS
Old 05-06-2018, 08:06 AM
Counterclockwise?
^^^ See above. Change the window felt. Yes there is pressure on the frame to form a good seal. You can adjust this pressure pretty easily, but then not have a good seal.
Old 05-06-2018, 08:25 AM
Thanks. Does changing the felt require removing the glass (and hence window frame)? It seems like it unless I'm missing something.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 05-06-2018, 10:39 AM
Counterclockwise?
It is done by just rolling the window down, pull out exposed felt and then use the window to pull out the felt inside the door. A couple of threads here somewhere.
Rod
1986 Carrera
2001 996TT
Old 05-07-2018, 06:33 AM
