Removing drivers seat
I am hoping someone can advise me on how to disconnect the wires from under the drivers seat on an ‘88 911. I’ve taking the rail bolts out and have the seat tilted back. Under the seat I see multiple wires but it seems there are only two that need to be disconnected. I see no obvious junctions to disconnect them to remove the seat (replacing carpet). I have the combination manual and electric seat. Any help is appreciated. This is my first Porsche and loving every minute of it. Thank you.
Ruxin
Old 12-21-2018, 09:36 PM
There are always connectors that can be disconnected to remove the seats. Look closer to the seats and perhaps post pictures.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-22-2018, 03:39 AM
Cars and Cappuccino
tdw28210's Avatar
Take pictures BEFORE you disconnect the seats. It may save you a lot of hassle when you go to put them back in.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 12-22-2018, 06:53 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Connectors.
Connectors.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-22-2018, 07:41 AM
The 2-terminal connector above is for the seat belts. The seat motors have a rectangular 8 position connector, 2x4 I think, near one of the motors (motor on the left in picture above). Since yours is part manual seat control, not all of the connector pins are needed, so you should only have 6 pins.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 12-22-2018, 09:13 AM
Seat.
Found a better pic.
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-22-2018, 09:55 AM
donagain1's Avatar
There was an alarm system in mine that had some odd looking wiring which went to a switch pad that was wedged between the zigzag springs and the foam.
Don
Rocklin, CA
-85 Carrera
Old 12-22-2018, 12:00 PM
sugarwood's Avatar
Removing the set was a PITA that I never figured out.
Weird hidden wiring connectors that are impossible to detach, etc.
This may help you.
Front seat removal. How do you disconnect the power cable ?
This was a nightmare that I could not get apart.
You may need a 3rd hand from a helper.
1986 Bosch Icon Wipers coupe.
Old 12-22-2018, 12:01 PM
I'm good with tools.
AG81's Avatar
It is NOT a PITA if you have done if before. I will say there is good advise in this thread. The main connector (larger dia. wire loom) has the large headed plug that runs the motors. The smaller wire is the seat belt connection. At least that is how my 88 coupe was connected.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 12-22-2018, 01:00 PM
This may help you.
Squeeze the two tabs on the side, pull apart.
Old 12-22-2018, 01:10 PM
Put a towel across the passenger seat, lower emergency brake and collapse the driver seat back forward. Then you can tilt the top of the driver seat over onto the passenger seat while wires are still connected. That is a much easier way to see what needs to be disconnected/reconnected than tilting the seat back up.
The seats are heavy.
But much easier to remove/put back in with a cabriolet. . .just saying.
Old 12-22-2018, 05:59 PM
