Anyone ever seen a door stop pivot pin like this??
I'm trying to figure out if I need to hammer it out from the bottom or from the top.
This pin doesn't seem to be factory... ![]() I don't want to mushroom it hitting too hard if I'm hammering it from the wrong end.
1987 Porsche 911 Carrera Coupe |
I think it has a ring keeper underneath
Bruce |
I looked underneath it, which is the right side in the pic (the longer section of the pin is the bottom... not sure why Windows 10 ALWAYS rotates my pics).... there is no metal tab holding it in.
It's just a hollow pin... but hard to tell if I should hammer it out from the top or bottom. I've been hitting with a screwdriver but no joy.
Here's a pic of the pin from underneath....
Logic would indicate the pin should be removed by hitting from the bottom. No obvious lip or ridge holding it in from that side. You might try inserting a nail into the hollow portion until the head butts up against the pin, then hit the nail on the head, literally.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Another idea, place a C-clamp over the pin with a small socket over the
top of the pin and crank the clamp to force the pin out. Might just work.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Apparently its not even a pin... just a piece of metal strip that someone rolled up into a cylinder shape and used it as a pin. no wonder it took such force. Ahh... the joys of PO shortcuts...
thanks... I saw this technique used in another thread... unfortunately the 'pin' was too tight inside and I couldn't squeeze it out any further.
Its factory. Its called a roll pin. being rolled up spring steel
82 SC , 72 914 |
![]() The more I work on this car, the more respect I have for professional Porsche mechanics/techs.
Its actually a good thing to use because it usually stays tight. If it was a standard sort of bolt play would develop and it would pop every time you open the door.
82 SC , 72 914 |
i second that from 930 dude... ..it is a factory pin..i like this pin much better then the later style...with the clip on bottom..these pins last for ever..Just have to be lubricated once an while as other things like a the door stop...
ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I put them out and in with channel lock pliers. Use a nut to push it through like a press
82 SC , 72 914 |
Uncertifiable!!!
This click-click when the door opens and closes is really annoying to me. In my previous P-car is had the rolling pin version but still had the clicking sound because the holes in the stationary body side were larger by just a little bit. On top of that, I don’t think the roll pin in very attractive. Looks a bit temporary.
So, on my new build, the RST, I used the frunk hood pins with the lock clips because with the roll pin it still clicked. There is more slack, it clicks just as much (ugh), but looks more OEM. I also smoothed out the pivot arm bumps both top and bottom a little bit to reduce resistance which helped reduce the clicking. Still looking for a non-clicking solution. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Here's a copy and paste of a post of mine. The procedure shown just may help with your click problem. I know you smoothed the "bumps" but this removes a bit more of the tension on the bumps. I did it to a stop and it seem to work. There is a great fix for the newer units that is much better than fileing down the "humps". The pics are self explanatory. Makes them less stiff and much easier on open and close.(and on the door sheet metal) Pics are not mine, but found on a Google search from another good Pelican. I have however done the procedure, and it works great! ![]() ![]() ![]() ![]() [/QUOTE]
Good time to reinforce the stock door stays so they don't rip through the sheet metal.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
It's just SHOCKING to think that there hasn't been any place YET I have opened up or worked on that hasn't already been messed with.
