bcgreen's Avatar
When first starting up after a couple of months of in activety
the gas pedal usually is stuck. I haveto pat it lightly a couple of times to free it up. I am guessing the linkage needs lube. What to use - a wheel bearing grease? Do I need to grease the linkage from under the car and how about the linkage within the engine compartment?
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 05-02-2018, 10:11 AM
I'd put the car up on stands, then have someone work the throttle while you study the action. First clean with brake cleaner, then lube all moving points. I'd probably use white grease which isn't too thick and will stand up to water.
May also be the pedal itself... time to remove and clean the pedal cluster?
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 05-02-2018, 02:51 PM
Administrator
Dmitry at Pelican Parts's Avatar
If it gets really bad, take a look at the link below to a DIY rebuild.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/40-Pedal_Cluster_Rebuild/40-Pedal_Cluster_Rebuild.htm
Old 05-02-2018, 03:26 PM
old man neri's Avatar
First place I would look is the bushing coming out the side of the transmission.
Old 05-02-2018, 04:02 PM
DanielDudley's Avatar
While you are down there, make sure the clutch line isn't rubbing the throttle.
Old 05-03-2018, 04:01 AM
bcgreen's Avatar
Will take a look and it will be my first time examing these parts.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 05-03-2018, 07:36 AM
