Shift lever help
Hello hello. I have had this car, a ‘68 912, for a few years and have just started to tinker with the interior. I want to replace the aftermarket Momo shift knob with something else, but I can figure out if the shift lever I have is the standard 901 lever, or something different. It is not threaded, the current Momo knob attaches with set screws, and then has a collar that threads on over the 3 set screws. I can get a good picture of a 901 shift lever, or the underside of a stick shift knob that came with the car from the factory. Thanks. Attached a picture of the knob, the lever, and the car. Thanks.
1964 Toyota Land Cruiser FJ45 1968 Porsche 912 1970 Citroen DS20 1972 Lancia Fulvia 1.3s Montecarlo |
The stock knob uses a crush sleeve to attach to the lever, it's not threaded.
Got it. Thanks.
That looks like a stock shift lever. To confirm, the top, unthreaded, steel tubing should have a 15mm diameter.
