How do you open the DME box?
I need to change out my chip. I watched Ingo open the DME box but now I can't get it. I have lifted the tabs and removed the circuit boards from the metal container. I understand there are two tabs near the plug that must be lifted but I cannot get the top circuit board to slide out. AM I missing something?
Paul:
On the side opposite the plug there are several plastic posts separating the two boards. They just snap apart, then the top digital board can slide out and open like a book. Tim |
Not totally accurate....
First..as you know...you need to bend the 10 ,or so, bottom metal tabs. Then, you look for the two posts ( as was said) and separate them axially from themselves by wedging something like a small screwdriver blade along the post. BUT now...in order to separate one board from the other...( like folding open a book), there are two push tabs that are in slots within one board, on the opposite side where the ribbon ( "hinge" for the two boards) is. Again, carefully use a small screwdriver blade to *gently* push down on these tabs one at a time, while pulling back one of the two boards...now the two boards should separate and fold open... (Easier said with a picture ... ![]() ---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Wil, did you say "Say it with a picture".... here they are:
The second picture shows the clips Wil was referring to. If you lift the board a bit, it should slip by the clips, otherwise do as Wil said. ![]() ![]() Tim |
Thanks, Tim...
In re-reading my post...I may have started-off a bit strong...but see you didn't take it the wrong way ![]() Thanks for the pics...exactly what I was trying to portray !! --Wil Ferch
Thread Tools | |
Rate This Thread | |
