Alternator rebuild shop recommendations or purchase rebuild
Hey everyone.
I have a 1971 with a 1975 2.7 CIS engine.. I am working on the wiring harness and a few other problems but was wondering if anyone had a shop recommendation to rebuild my 71 alternator or should I just purchase a 75 or later alternator? There was also talk to upgrade to an external voltage regulator. What are the benefits?
Thanks in advance.
Old 05-20-2018, 07:37 PM
Under the radar
Trackrash's Avatar
The older alternators tend to be longer lived than the newer ones. That might be because newer cars have a higher electrical demand. At any rate getting the '71 rebuilt is a good option. Unless you have air conditioning, then an upgrade may be in order.
All of the cars up to the Carreras had external regulators. You can get solid state replacements which is probably the way to go.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-20-2018, 08:56 PM
Great. I googled an alternator shop specializing in Porsche and could not find one. Does anyone have a recommended shop?
Also is this the solid state VR mentioned above?
https://www.pelicanparts.com/catalog/SuperCat/5867/POR_5867_ELCHRG_pg1.htm#item3
Old 05-21-2018, 04:02 AM
Virtually any good shop specializing in alternators and starters could
rebuild your alternator. I've had Porsche alternators rebuilt by several good shops. Rebuilt/reconditioned alternators in the market place are at best a crapshoot, there are many POOR commercial rebuilders out there, including Bosch! A lot of them just replace a few components to save money, not a complete remanufacture like a good local shop will usually do, plus if you have a problem you can address it locally. Best to rebuild your known good core. Just my experience.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-21-2018, 07:26 AM
Under the radar
Trackrash's Avatar
Yes, make sure you get the regulator that matches the brand of alternator you have.
As mentioned any shop that can rebuild an alternator can do the 911s. The Motorolas found in the old 911s were quite common at the time and various versions were used in many cars.
Some of us have rebuilt our own, BTW.
Gordon
Old 05-21-2018, 07:51 AM
