gumba's Avatar
tach signal from coil with cdi
Can i get a tach signal from the coil to run a shift light?
I have a twin plug Bosch distributor with 2 coils and 2 cdi boxes on a 3.5 turbo motor.
I've tried a couple of shift lights T ing off the tach wire at the tach. The MSD shift light sort of works occasionally. The other box I tried didn't work at all.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 05-17-2018, 01:09 PM
Jonny H's Avatar
No, the coil primary A terminal has a -400V pulse. You could try getting tbe RPM signal from the TD pin on back of the tacho which may be a more compatible voltage level.
P.s. Our CDI+ units have a programmable shift light output and rev limiters built in.
www.classicretrofit.com
Old 05-17-2018, 01:20 PM
gumba's Avatar
No luck coming off the back of the tach.
Your boxes would be great if I hadn't had my 2 boxes rebuilt a few years back.
Thanks for the reply.
Harold
Old 05-17-2018, 01:26 PM
I have one of these which I use to get a signal from a coil to a data logger. It works well.
https://www.ebay.com/itm/UNIVERSAL-TACH-ADAPTER-CONVERTER-COP-1-2-3-4-5-6-8-10-cyl-to-any-4-6-8-Tach/141931549970?hash=item210bc79512:g:YiQAAOSwwG9ZmOo p
Davin
'87 Carrera 3.2
'66 VW Camper
'59 VW Beetle
Old 05-17-2018, 06:17 PM
Under the radar
Trackrash's Avatar
Are they 6 pin CDIs? Have you tried the tac output on the CDI?
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-17-2018, 07:51 PM
gumba's Avatar
6 pin cdi's. the tach output works fine on the tach. I T'd off the tach line at the tach. The shift light is inconsistant.
Harold
Old 05-17-2018, 07:57 PM
