I need help with this:
I recently converted my 914 to 916 look then I need wider wheels. My problem is at the rear because I want 9" Please tell me the backspace or offset of the 9 x 15 fuchs wheels. I received an e-mail from wheelenhancemnet and told me that the offset of this: 9X16 15 mm 8X15 10.6 mm 9X15 ? 8X16 ? If aprecciate a lot if somebody tell me the difference between backspace and offset ? |
8 x 16 is the same offset backspace = is the distance from the back lip of the wheel to the mointing pad of the wheel. offset = is the distance from the center of the wheel to the mounting pad of the wheel. |
Hi Eduardo,
ALL Fuchs rims, with the exception of the 9X16 and the 7X15 type 911R have 120mm backspacing. From that you can determine the offset. For a 9X15, it should be about 3 to 5 mm. I hope it's correct, but I think it is. Regards, George |
