umop apisdn
Not required for CIS-Lambda, so save yourself some money here if you have a Frequency Valve in your system
Steve 1981 928S 4.7 ROW with KE3-Jetronic "Be the man your dog thinks you are." www.FrankenCIS.com |
El Duderino
Steve,
Thanks for jumping in. I thought I was sending an email to you and an email to Dkubus. Somehow I ended up sending two emails to Dkubus - one to ‘info’ and the other to ‘sales’. Sorry. I was trying to get to you. That’s excellent background info. Very helpful. And it appears you’ve done a lot of good work. As these CIS cars are getting older, I think options are good. I was just stunned at the price quote I received from Dkubus. That’s a non-starter to me. Maybe I am missing something. If a block isn’t required for CIS lamba, where does the injector that adjusts control pressure mount?
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
umop apisdn
with CIS-Lambda there is no actual need for control pressure adjustment, the Bosch WUR is sufficient for initial warm up and basic control pressure maintenance.
All of the actual system tuning can be done using just the Frequency Valve and FrankenCIS The frequency valve as greater range, accuracy and responsiveness than the control pressure circuit can provide
I was fascinated by this thread,,,very educational..but for us non techie folks..what is the WUR replacement option for NON Lamba vehicles (83 SC)?
Thanks Tirwin for this thread. You and others have answered most of the questions that were in the back of my mind.
My 81 SC Turbo conversion works pretty well with CIS and BL Wur so no strong motivation to change. Everyone seems to blame the WUR for all of their problems. Would any of these systems work better as long as you are using the fuel head and injectors that came on the car? My opinion at the moment is to stick with what I have and if I want a complex expensive project in the future I will go with EFI and COP just because it's cool.
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
You don't have to go all-out; some people can resist "while you're in there". A lot of folks had good success with simply adding modern injectors to CIS manifolds - even for 930's, folks have made large HP numbers on the factory pancake just by ditching CIS. You might not get the absolute best results - depending on what you were going for - but merely ridding yourself of CIS injectors can be a big win. Which I think is the Achilles Heel of FrankenCIS - as interesting as the approach is and props to the folks doing it - because it retains CIS and adds yet more stuff... Which seemed appealing once - but now I think "if you're already adding a bunch of sensors, harness, ECU - why not bolt on two fuel rails and an FPR so you can use real injectors - and junk a whole pile of obsolete things?" (Sorry to you guys in Cali.) Any modern injector has vastly superior fuel atomzation compared to a CIS injector - and just firing fuel when the motor wants it instead of acting like a lawn sprinkler 100% of the time? kind of a big thing. And that's before you get fancy with tricks CIS can't do, like sequential versus batch injection, injector pulse timing, load-based cylinder trims... Once you're at that point, it's a small step to add ignition maps and drive COP - hotter/longer spark, no distributor, individual cylinder trim if you want. To answer jjeffries's question; the difference between a CIS car and the same car converted to EFI should be night-and-day; sharper throttle response, more power with better fuel economy and cleaner running. CIS has a certain olde-worlde charm. Like my 915 did. Everyone has their own criteria/preferences/bias/direction. So it's all a personal choice. There's a chap on this (very old) thread CIS to EFI Conversions? that converted his SC to EFI using all factory EFI from an '85 Chevy 2.8 V6 - which apparently set him back $150 in parts from a boneyard... You need to put time/skills/learning into that equation to make it work. Or buy a bolt-on kit from someone who already applied a bunch of that. Or have a shop do it. Something for everyone...
'77 S with '78 930 power and a few other things. |
Excellent information, much appreciated. Any day when you learn something is a good day! Best regards to all, John
