CIS trouble - low idle during warm up
Hi guys,
I have a friend who have some problems with his car. On cold start, the car is doing some yoyo during the first 2 minutes. After that, the iddle gows down to 500 RPM and slowly reaching 950 RPM. When the car is hot, it works preaty well. Here is the car configuration : - it's a 3.2 with a 3.0 SC european engine - the fuel distributor came from a 188 HP engine - the Wur came from a 204 HP engine - the auxiliary air valve closes within 8 min - the engine was recently rebuild with 964 cams and Malhe 97 mm pistons - all the CIS parts were rebuild and setup correctly and or tested separately - the mixture was setup to 2.7 - all the ignition parts are also new We sticks with this problem for a while and couldn't figured out was causes the issue. I hope I made myself clear enought ![]() Thanks a lots for your help. cheers Last edited by deftom; 05-28-2018 at 01:24 AM.. |
CIS troubleshooting.........
I like to help you but your information is too vague. Please provide the following: FD ID Bosch number WUR ID number AAR ID number What do you mean mixture set @ 2.7? What are your fuel pressures readings (cold, warm, and system)? How is the integrity of the vacuum system? Did you test it? Keep us posted. Thanks. Tony |
Hi Tony,
Thanks for your help. here is the information you asked : FD ID Bosch number : 0438 100 031 WUR ID number : 0438 140 089 AAR ID number : 0280 140 201 What do you mean mixture set @ 2.7? 2,7% measured with a gunson gastester What are your fuel pressures readings (cold, warm, and system)? Cold = 1b @7° celsius, Warm = 3,1b without vaccum (3,8b with vaccum), System = 4,5b How is the integrity of the vacuum system? Did you test it? Yes, everything seems to be fine Thanks ![]() |
Hi guys,
After few research, I foudn something that my be our problem : 1981 SC CIS - low idle - wrong WUR? I'll keep you in touch if it's that. Cheers ![]() |
You also need to check the AAR and make certain that it is opening and closing properly.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Actually, He already tested it. When it's cold, the TAA is open and i took 8 min to close.
Still here
Have the timeline for the FP as well ?
Thread Tools | |
Rate This Thread | |
