Flojo's Avatar
Carrera jack points - part number?
Hello,
did some searching, also parts catalogue, but could not find the part number for the Carrera jack points that are OEM welded to the chassi.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 06-04-2018, 06:38 AM
/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
I don't know the part #, but they aren't on all Carreras. My '84 doesn't have them, but my '88 did.
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 06-04-2018, 06:47 AM
I found "bracket for jacking point": 911-507-535-00 (left), and 911-501-836-00 (right) in the PET (page 200). These are listed there, but there is no picture/drawing. This seems like it could be it, but...good luck!
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 06-04-2018, 06:56 AM
Flojo's Avatar
Thanks Lyle, found it in the 87-catalogue.
Yes indeed, no picture.
Asked my parts dealer if they are spare purchaseable.
@Luftkul, I was planning on adding them to my SC as I'm fed up with messing around with pads and properly setting the lift arms not damaging the floor and so on.
Old 06-04-2018, 07:14 AM
carreradpt's Avatar
What did you find out Flojo? Can they be purchased?
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 06-04-2018, 07:41 AM
proporsche's Avatar
flojo..i have been using simple floor jack and lift the car by the engine for over 35 year never had to use the body to lift 911;-)
The only thing you will do is damage the original Porsche undercoating...which is held pretty good on all 911`s...
just my thought to your being fed up lifting the car on the floor;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-04-2018, 08:43 AM
Originally Posted by Flojo View Post
Hello,
The left side 911-507-535-01
The right side 911-501-836-00-GRV
They will have to be ordered out of Germany. Allow 3 weeks
1987 Porsche 911 Carrera Coupe
Old 06-04-2018, 10:00 AM
carreradpt's Avatar
Ivan
For those that have a lift, they would be very helpful and a big time saver.
Dan T
'85 Carrera
Old 06-04-2018, 10:55 AM
proporsche's Avatar
Hi Dan ..in a shop when you have a lift you can use the sway bar bracket place and front body edge..never need to worry about the floor....All i am saying is once you start welding into the original body and removing the Porsche undercoating you are asking for a trouble , rust.....
Any time i had to replace the broken sway bar bracket in the shop i did not like the works of some shmuks who used welding with fire-tools-torch The best is arc welding ..or spot welding
that is my take on this;-)
Luftkul...
The Lifting bracket were introduced in 1987 Carrera.....
Old 06-04-2018, 11:29 AM
Uncertifiable!!!
Uwon's Avatar
My ‘78 has 10mm threaded holes at each corner by the outboard seams. These were plugged by the factory and coated. I just countersunk the bolts+wide washer into standard hokey pucks and bolted them. Cannot remember which ones I had to drill slightly off center. One I also had to but a slight notch to go over the seam. Dry fit will tell you.
Nice thing is that it still give you room to slide the jack in on a lowered car.
Just an alternative.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 06-05-2018, 03:36 AM
(man/dude)
Jonny042's Avatar
Johan
I did exactly as Johan did. Must be a Canadian thing...... the rears needed a bit of a chamfer to fit neatly and flat against the pan, or you could drill the hole off center. Pics in my thread:
Custom hoist/lift support pads
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 06-05-2018, 11:07 AM
