ignition switch - expected behavior
I had an issue a while back i posted about - https://forums.pelicanparts.com/porsche-911-technical-forum/992848-ignition-key-issue.html,
and had a new key cut from the code - which seemed to work great. I also bought a used cylinder and had it re-keyed by Sierra Madre. I was nervous to install it though because while it turned, it didn't seem to have a reistance point beyond which the starter motor would kick in. I now seem to have the same problem in my car with the original - it turns fine to the ignition on position - but there is no way to turn it further to activate the starter. What's killing me is that last night it worked fine. Am I going crazy, or do they both have the same problem, and is there in fact a 'resistance point'? Thanks, Nikos
1983 911SC 2005 911S |
Senior Member
Others will know FAR more than I about your question. That said, according to my understanding, if a new ignition switch is used and the key fails to turn far enough to engage the starter, then this means your ignition tumblers are worn and need to be replaced.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Take the tumbler out and remove the spring and pin at the bottom. The pin catches on the ramp.
The detents - clicks - in the ignition positions, as well as the spring resistance against "Start" - are all in the electrical switch. You could try detaching it and check that it behaves as expected with a screwdriver. I guess it might be possible for that to mess up internally - although it seems to be more usual for the contacts to arc inside. The late electrical switch - the 964 part, as opposed to the 911 one that used to be double the price before going NLA - has an internal mechanical lockout for "Start" - once you've hit it the first time, you have to turn key back through/back past "On" before you can hit it again. I hate that... Keep meaning to open one up and see if that's easy to remove...
'77 S with '78 930 power and a few other things. |
