Engine Compartment Missing???
So I am the proud new owner of my first 1979 SC (minus the engine) and I have already made some nice friends on this site. I bought an engine from I wuv DaPorsches and I am getting the engine compartment ready for it. Can someone send me a picture of what the drivers side of the compartment should look like? I think I am missing some things but not sure. Thanks
Old 06-12-2018, 04:07 PM
Registered Minimalist
75 911s's Avatar
The engine bay has been stripped of the stock relays and parts. It looks like the previous motor's intake may have been carbs judging by that aftermarket fuel line and regulator and it probably had an MSD style ignition as the CDI box is gone.
Some of the missing things are the CDI box, the relay and fuses for the rear heated window and heater blower motor.
What is the motor you bought, and what intake and ignition do you have on it?
Did they do the 964 conversion on the back too?
I think it depends on what direction you are going. A long way to return to stock, so might as well enjoy a hot rod. Congrats!
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 06-12-2018, 04:11 PM
Mark Salvetti's Avatar
If the missing motor was carbs, would they have used a different fuel pump up by the fuel tank, or just used that regulator to lower the fuel pressure?
Also missing is the fuel accumulator and fuel filter. I wonder if what's left of the fuel lines will work with a CIS motor.
Mark
1979 911SC Targa
Old 06-12-2018, 05:41 PM
Yes, the back has a 964 conversion also. The motor is 3.0l CIS.
Old 06-12-2018, 06:48 PM
75 911s's Avatar
Wow nice clean motor. Do a WTB ad for the whole panel and components, or get on the PET and start getting part numbers. Keep us posted.
Old 06-12-2018, 06:54 PM
But that fan pulley looks to be a mess. Post a closeup, something looks very wrong there.
Mark
1979 911SC Targa
Old 06-12-2018, 07:27 PM
SalParadise's Avatar
Dude you better be sure about those motors - they are suspect. Lots of silver paint, ArmourAll, and other suspect things going on. If you're going to plug and play do your homework or it may be a living nightmare.
Old 06-12-2018, 08:12 PM
Cairo94507's Avatar
When I see that much shine on anything for sale......I get cautious unless the seller is someone with a stellar history and reputation in business. Good luck.
'71 914-6 #0372
'17 Macan GTS
Old 06-13-2018, 06:11 AM
Thanks for the help and advice. The motor arrives next week so i will know for sure but other Pelican's have vouched for the seller so I am hopeful.
Old 06-13-2018, 12:36 PM
Vintage Owner
Jack Stands's Avatar
The car definitely was running carbs, so figure a fuel pump, accumulator, lines, etc. as well as the electrical components. You might do well to check the parts book (PET) to track down the needed parts.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 06-13-2018, 01:41 PM
