lateapex911's Avatar
Question Distributor advice needed...
hey folks...I'm hoping someone can help me with some info.
In my quest to re-do my ignition system, I've run into a road block. My car, a '73E, has a 2.7 engine, which uses a '67 case, I'm told.
In getting the number off the distributor, I discoverd that the distributor is from a 67T and L. Uh oh!
The engine has Weber IDAs, Solex grind cams, if I remember right, SS heat exchangers, and a sport muffler. Roughly 9.0 compression.
So...what is the appropriate distributor? And a good source for it? I would prefer post '72 items to allow the option of the Pertronix Ignitor.
Thanks in advance for any help!
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 02-28-2003, 07:00 PM
Cool
I would get a 2.7RS dizzy.. Pelican Parts should have them for less than $300/great price.. the curve should be perfect for carbs and early solex
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-28-2003, 08:39 PM
