Help I.D. Distibutor Part Number
Hi Guys, have a 912 that needs tune up. I picked up stock Dist Cap and rotor (Bosch) but they didnt fit. So it is obviously an aftermarket of some type. Here is the numbers stamped on the Distributor. Any help to determine what type it is and what the part numbers would be for:
1) Dist Cap
2) Rotor
3) Points
Thanks for helping a Porsche newbie.
"If it turns heads, it's a cool car"
Old 04-07-2003, 08:39 AM
What are the last 3 numbers on the distributor?
Old 04-07-2003, 11:30 AM
The last 3 number are 050 (duh) I guest that calls out for an 050 Distributor?
Old 04-07-2003, 01:35 PM
INFO FOUND!
Thanks guys, just typed the number on the distributor into www.google.com AND bingo got all the info I needed.
Old 04-07-2003, 10:26 PM
Pertronix makes a nice electronic ignition unit for the 050, eliminates the need for points.
C
Old 04-09-2003, 10:02 AM
Hi Craig, thanks. I'm going to go that route after I get it runing straight. Tracked the number all the numbers down for the Dist, cap, rotor and points...anyone need them just ask.
Old 04-09-2003, 10:15 AM
