912 Engine Replacement
If a 912 replacement engine was purchased from Porsche in 1969, would it be stamped with a 1969 type number, i.e., 409---- or would it have no number?
Old 11-08-2021, 02:02 PM
No serial numbers on the 3rd piece of a replacement engine.
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 11-09-2021, 08:23 AM
What is the third piece of an engine replacement? Thanks.
Old 11-11-2021, 11:14 AM
... not just a replacement motor/case but every motor;/case it also referred to as the timing cover. Two pieces are the case halves, the third piece covers the crank/cam gears and houses the distributor, fuel pump and some oil system pieces. A replacement motor/case will have no serial number on the timing cover; a replacement case will have a 'K' embossed on the left side case lug, just ahead of the generator stand:
Peter
1968 912 SW Targa (Restoration: almost Tangerine again)
1986 951
2013 Cayenne Diesel
Old 11-11-2021, 12:46 PM
Blank clean !
Old 11-12-2021, 10:11 AM
Thanks for the education. Since the engine has a serial number (4095137) and there was a number on the 3rd piece under the oil filter that coincides with the '69 model year, I am guessing that the engine began life in a '69 912. No idea what happened, but the engine was replaced in 1969 so basically a new engine.
Old 11-12-2021, 04:18 PM
