Wires from generator to voltage regulator
Hello friends 😃
Can some of you tell me if (how) the wires from the generator to the voltage regulator are specified in respect of length, thickness (mm2) and insulation? The generator is the small one - 350 W, Ø 89 mm. Does it matter if the length of the three wires are shortened each by 25 cm? Regards Palle Last edited by porschepalle; 08-20-2023 at 12:53 PM.. |
Ok...... :-)
Hello, you will have a much better response at this site....
https://www.912bbs.org/forum/ Kinda S L O W here:<)
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
Palle:
You can shorten the wires but allow extra length for engine movement. As far as gauge, the D+ requires a thicker gauge (i.e. 12 ga) while the wire to the charging light on the dash can be thinner. Just be sure the wires are stranded copper and intended for automotive use. Also, when in doubt, go with a thicker gauge. Bill |
Thanks for your reply. I have been there - got a nice and usable reply from Peter Graham. Regards Palle |
Thanks for your reply. It is nice and very usable. As you may guess I intend to make the wires by myself. Regards Palle |
Banned
Was useful thanks
