judder when reversing
My 1966 Porsche 912 has started to judder and vibrate when reversing. It is becoming almost impossible to reverse uphill.
Does anyone know what may be causing this?
It does not hapen when i pull away forwards.
Thanks,
Paul
Old 08-21-2003, 01:53 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
I suspect....
that you have a cracked front transmission mount. Check the mounting pads. They can be replaced easily enough - you don't have to remove the trans from the car.
Mark Petry
Bainbridge Island, WA
Old 08-21-2003, 02:30 PM
Thanks Mark,
The front transmission mounts were my first thought, but when I crawled under the car they look ok. I'll check them again and maybe replace them regardless.
Why would these only cause it to judder when reversing and not in first gear?
Paul
Old 08-22-2003, 02:13 AM
Quantum Mechanic
mpetry's Avatar
the other possibility
Is that you have a hot spot on the flywheel. The reason it's more apparent in reverse is that in first you engage the klutz and then drive off, 2nd, 3rd, etc. In reverse you just slip the klutz, and that causes the vibration.
Mark Petry
Old 08-22-2003, 05:39 AM
Please excuse my ignorance, what is a hot spot on the flywheel?
Old 08-22-2003, 07:47 AM
