case assembly
when assembling your case do you use thread locker on the case bolts or not. thanks
Old 05-28-2004, 10:16 AM
C. Clark's Avatar
To Loctie or not to Loctie, that is the dilemma
Chas.
69/912
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 05-29-2004, 05:33 PM
abit off center
cgarr's Avatar
The only thing I used locktite on was the rod bolts and the flywheel nut. After reading the above post, your guess is as good as mine, pal nuts, safety wire?? Just torque it right and you will be fine,
Craig
______________________
Craig
G2Performance
Old 05-29-2004, 07:24 PM
Morrie's Avatar
I guess you are either a fan or you are not, but the HCP Research videos on engine assembly do an outstanding job of walking you through putting the engine together bolt by bolt. We actually had the VCR out in the garage and built our motor right along with Harry. Lots of good tips.
Just my humble opinion....
Morrie
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 06-17-2004, 12:12 PM
